06 HV Battery Module Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dr3wst3r, Jun 17, 2017.
  1. JC91006
    16,936
    8,647
    Did you replace 1 module in block 8? Or 2?
  2. dr3wst3r
    dr3wst3r Junior Member
    22
    Seattle
    Ok well good news. Looks like I was stupid and did not tighten one side of the bolts for block 14 and 13(closest to the controller) or modules 1-4 in my chart on page 1. I have tightened the bolts and the errors have been cleared. I am driving it around now and it seems to be looking good and relatively balanced with the other batteries. I think that I will do another long charge and balance. My replaced module (block 11) still seems to be lagging a bit behind, but is pretty close. JC91006 I think some of the voltage difference was due to accelerating during the "Power Breaking".
    Below are some more screen shots after tightening up the nuts on the modules.
    Idle W/ AC??-[​IMG]
  3. JC91006
    16,936
    8,647
    I think you replaced block 8? not 11.
    Anyways, if there are no errors, great. Do a 15 hour charge, then discharge to 134v. Then a 24 hour charge/balance. That should be good.
