06 Prius Brake light, ABS light (!) thrown after -5 temps HELP!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LezlieS21, Jan 16, 2024.
  1. ChapmanF
    19,042
    Has anybody anywhere in the world ever said what the ever-lovin' trouble codes are yet?
    Danno5060 and Tombukt2 like this.
  2. LezlieS21
    LezlieS21 New Member
    Colorado Springs, CO
    Update: the code was: C1343 rr hydrologic system malfunction
    The mechanic who scanned it said it could be just a bubble in the break line (especially since it happened on our coldest day sitting outside at -10*) and so he cleared it and said if it pops up again let him know and we will then investigate further.
  3. ChapmanF
    19,042
    I'm not sure how a bubble in a brake line would be connected to the temperature, but yes, let's see if it comes back.
    The good news is that code by itself does not necessarily mean anybody needs an actuator.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Maybe ice in the brake fluid? If there is water contamination I can easily believe that the ABS would malfunction when it tries to open or close a valve and finds crunchy solid stuff in the way. On the other hand, if there is just water, which is a fluid and not a solid, it could easily work just the same as if it was brake fluid.
    BiomedO1 likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    Good thought but unlikely.
    Brake fluid absorbs water and disperses it throughout over time. That will affect boiling temperature and will cause corrosion inside the system.
    Since DOT 3 freezes at -40°F I imagine it would take a "huge" amount of water contamination to cause problems at the noted temperature.
  6. LezlieS21
    Well we are at high altitude and it was the meterological "river" where it was blizzard conditions and -10 plus I was parked at a semi incline. So, my fingers are crossed for now. Thank you ALL!
  7. ChapmanF
    19,042
    I'm not sure how a bubble in a brake line would be connected to any of that, but yes, let's see if the code comes back, whatever was actually going on.
  8. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    How did the car do when the weather warmed back up again? How does the brake fluid in the reservoir look?
    Before spending big $, I'd try replacing the fluid in the master cylinder and bleeding all 4 brakes. (I've only done this the old-fashioned way which pisses off the ABS computer - which takes a bit more than the bottom-end OBD2 tool to clear the codes.)
  9. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Good news is the hybrid mechanic, cleared the code and gave you back your Prius. Even if he's told you he's not exactly sure what the issue is yet, he also mentioned if the code or ABS light come back to bring your car back and he'll investigate further. Seems reasonable to me.
    Stay Safe, happy and warm.
    LezlieS21 likes this.
  10. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    I was just about to mention that, brake fluid absorbs moisture out of the air. I believe your suppose to replace every 3 - 5 years, depending on humidity in your area.
  11. Mendel Leisk
    42,364
    Just for giggles jack up the rear and see if the wheels spin semi-freely, with the parking brake off.
  12. LezlieS21
    Thank you!
    After it warmed up my car felt different (meaning it felt back to norm) and so we had the mechanic come 2 days later (still above freezing) and he does have an idea what could be happening and how to fix it. However, it said it could ALSO be this "quirk" like thing (over 250 cars in the CO springs area went to mechanics after that day) and just see if it pops up again.
    I had my brakes checked 1.5 years ago and they were still good. Due to low humidity here in the mountains, I will have it rechecked in the Spring (May-June)
    vvillovv likes this.
  13. BiomedO1
    4,635
    2,433
    Left Coast
    There's a moisture sensor tool that you dip into your brake fluid to see if it's still good. The color of the brake fluid should be a light amber color; like a light pilsner beer - not light brown.
    Whenever I buy a used car; I always flush-out the brake system and replace the fluid. You'll be surprised how well the braking system responds; because the deterioration is so slow it usually isn't noticeable.
