06 prius mpg gone way down
Discussion in 'Gen 2 Prius Fuel Economy' started by callie barrett, Aug 13, 2017.
  1. callie barrett
    callie barrett New Member
    amelia island fl
    Four Touring
    have 06 prius with close to 200000 k on it. Car lost all power and would not start. Prior to this was getting 40-45 mpg all the time. Had fuel pump internal failure and had whole tank replaced along with 12V battery pack. Now MPG is averaging only 30- 33 mpg? What gives and how do I get it fixed
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    An 06', thinking the traction battery is due, if you spend the 2500$ you get five years of almost a brand new Prius, depending on tires brakes and struts, go to a Toyota dealer and get an estimate, possibly two estimates, at the moment the ice (internal combustion engine) is doing the work, I'm assuming, and the traction battery is along for the ride.
    If you save a 1000$ dolla s on a rebuilt traction battery, well I'd advise buying a new one, but it's your money.
    #2 Lucifer, Aug 13, 2017
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    First you should be checking your mileage with the "manual" method and not trusting the onboard display.
    If you are already doing that.........sometimes a sudden drop in mileage is an early sign of the HV hybrid battery failing.
    10-11 years old with 200K miles is a good run for the HV battery.
  4. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    Are you in habit of reseting the average MPG on the consumption screen every time you fill the tank?
    If not, the average MPG will have been averaged over several 100,000 miles which means as your HV battery was (possibly) declining you will not have noticed it.
    When the 12 V battery was replaced the average consumption will have been reset back to zero, and so now represents a more true value of your average consumption. It may well improve a bit, if this is below your normal average, but the apparent drastic drop will be because the average consumption meter was reset back to zero.
    The lack of power symptom (and the low MPG) does indicate a HV battery on the way out, expect to see some error lights appearing soon.
    #4 dolj, Aug 14, 2017
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    If I remember right, a 2006 Prius has a gas bladder not a actual tank?
    So, I'm just wondering how you are calculating your gas mileage.
    I'm thinking a "new" gas bladder might of changed everything. Might not be holding as much fuel as before.
    It certainly could be a sign of a failing HV battery but I'd want to evaluate MPG manually. Curious if your new gas bladder might be holding a lot less fuel.
    #5 The Electric Me, Aug 14, 2017
  6. dolj
    dolj Senior Member
    8,648
    4,398
    It has a bladder inside the tank.
    And no, it shouldn't change the dynamics much, especially the onboard average/instantaneous MPG on the MFD.
    The bladder may cause tank to tank variances, but averaged over multiple tanks it should even out.
  7. callie barrett
    amelia island fl
    Four Touring
    FORGOT TO MENTION THAT THE HYBRID BATTERY PACK WAS REPLACED AT AROUND 100K.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    With what? New from Toyota or rebuilt (aftermarket company)?
  9. The Electric Me
    9,083
    5,801
    What I'm wondering is if the OP has monitored how much gas his new bladder is holding.
    Being entirely new, it may not be holding as much as his old one, which (if not paying attention to how much fuel you are actually putting in) could explain the sudden MPG loss.
    Bladder "inside" the tank...is gas bladder.
    2010 Gen 3 Toyota changed to a more conventional gas tank.
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    MPG = Miles Per Gallon = Miles Driven / Gallons used (refilled) = Actual Fuel Economy
    MPT = Miles Per Tank = Miles driven form "F" to "E".
    The "new" tank has a new fuel level sensor, from what I can tell; but have never seen any documentation on, the display acts like it uses tank LEVEL to guestimate fuel economy, instead of calculated fuel use (injector total "on_time" times "flow_rate") over miles driven.
    Miles Per Tank is in no way equivalent to Miles Per Gallon for calculation of fuel economy.
  11. callie barrett
    amelia island fl
    Four Touring
    [QUOTE="fotomotK
    Hybrid battery pack replaced by Toyota at around 100K, now has close to 200 K
  12. Lucifer
    1,014
    486
    Nh
    Ok, one of your spark plugs must be fouled, have the obd2 port read, a plug missing will show up, if not, ;) another traction battery....
  13. The Electric Me
    9,083
    5,801
    But the most accurate way to really gauge your fuel usage is to reset your trip computer on fill up...have a full tank, drive until you fill up, note exactly how much fuel you have added and divide by number of miles driven. Then repeat....
    That's far more accurate in my experience than any MPG that nearly any vehicles MPG software or feedback has ever given me, including the Prius.
    So I disagree...how many miles you are going between fill ups, as long as you know exactly how much fuel you are adding at every fill up and exactly how far you've gone ( Miles Per Tank ) is a GREAT way to calculate for fuel economy.
    I'm not saying I am right. It could be as complicated/simple as The OP does have a hybrid battery about to fail.
    The only reason I'm promoting manual calculation of MPG and noting how much fuel per fill up, is the OP say's this MPG drop happened right after having a fuel pump failure and replacing the fuel pump and the "entire tank". Which makes me look in that direction.
    It can't really hurt. Worst case scenario? The OP get's a real good idea what his MPG actually is, and his Hybrid Battery STILL throws a code and he still is faced with the same challenge.
  14. 05PreeUs
    1,097
    565
    MSP
    No. You have absolutely no WAY to run a vehicle to the same fuel level each time and the inaccuracies of the level gauge leave much to be desired. The only way this works and it can, is if you run to empty, as in no fuel left. Then tank after tank, you can gauge any change in efficiency; presuming of course that you were no on an incline when you ran out.
    It does not matter one iota, if you add 3 gallons or 300 at a fill (Prius or Big Rig), the math is still Miles Driven divided by fuel used.
  15. The Electric Me
    9,083
    5,801
    I don't disagree with that. In fact that's what I've been saying all along.
    " But the most accurate way to really gauge your fuel usage is to reset your trip computer on fill up...have a full tank, drive until you fill up, note exactly how much fuel you have added and divide by number of miles driven. Then repeat...."
    #15 The Electric Me, Aug 19, 2017
  16. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    ...and repeat, repeat, repeat. Then average it over the course of multiple tanks.
    You are correct in post #9. The new bladder may be holding a different volume than the old one. Even the same bladder holds a different volume every time you fill the car up. Averaging over multiple tanks is still the only way to even approach an accurate reading.
    The Electric Me likes this.
  17. Helen E
    Helen E Junior Member
    17
    Atlanta, GA
    My 2006 Prius only has 67,000 miles on it. Is it the miles or the 12 years?
    Are ALL Priuses needing a new $3,000 change?? I am pretty upset as I live in an area with zero public transportation (Georgia) and being a widow on social security I am very worried.
  18. fotomoto
    5,639
    3,815
    So. Texas
    Yes, it's time not miles. All batteries fail eventually. My 06 only has 54,000 miles and needed the original battery replaced last year. I got a new Toyota pack here in Texas for $2500 installed. There are several choices for replacement from used (refurbished) to new with prices ranging from $500-4,000. Start your research now and you'll be better prepared for the eventual failure that is coming.
  19. Helen E
    17
    Atlanta, GA
    Took my 2006 Prius into Rick Hendrik Toyota in Atlanta with 31 mpg. I told the service guy David that I might need a new hybrid battery? He said “There are a LOT of things that can cause dropped MPG..let’s check them all.”
    Previous maintenance a week before in Douglasville gave me all green boxes for tire tread, camber, axle, etc. “No worries.”
    In Atlanta, two tires are nearly bald, and a chunk was taken out of inside side wall. (After driving 60-70 miles) 4 new tires. New alignment.
    MPG now back to 47.
    Glad I have an honest service guy...I HATE driving into Atlanta but I have to. Atlanta is the only major city in the USA with THREE Interstates running through it. I-20, I-75, I-85. Traffic REALLY sucks.
  20. Helen E
    17
    Atlanta, GA
    Anyway--hybrid battery pack was A-OK.
