06 prius transmission problem? I dont get it
Discussion in 'Gen 2 Prius Technical Discussion' started by kberven65, Aug 23, 2015.
  1. kberven65
    kberven65 New Member
    24
    pierre sd
    Had codes read at the dealer. No codes besides a cylinder 4 misfire. Which also threw an p0138. Everything else was fine. Stuck valve?
  2. JC91006
    16,933
    8,643
    how many miles on this engine? are you sure this new engine is good? Not one that was replaced because it was bad?
  3. kberven65
    24
    pierre sd
    It ran fine for a couple hours before it started acting up. That's what I don't get. Drove it 100 miles yesterday to see if I'd come out of it and it didn't.
  4. kberven65
    24
    pierre sd
    Was a engine pulled out of a salvage vehicle
  5. kberven65
    24
    pierre sd
    120k on new engine
  6. JC91006
    16,933
    8,643
    swap the coil on cylinder #4 to another cylinder, see if the misfire goes with the coil. Since your spark plugs are new, I would hope they are good
