06 Prius with C1554 Error Code
Discussion in 'Gen 2 Prius Main Forum' started by DAM0, Feb 15, 2018.
  1. DAM0
    DAM0 Junior Member
    26
    New South Wales, Australia
    Hello friends, my prius was driving fine the other day and then the steering assist totally died randomly. After scanning it today it's shown code C1554, which from what I could gather from the scanner, seemed to be pointing towards the electric steering assist motor no longer functioning. However, from further research, many people seem to go straight for the steering ECU (under top panel of the dash?). I have the PS warning letters on my MDF screen. I thought it was weird for the PS ECU to be dead if the diagnostic systems all seemed to respond well showing input and output voltage and currents.
    All my input torque voltages seemed to be responding fine, but all zeros on the output front. Has anyone had the same issue and can help me? Mine is a right hand drive car if that matters.
    Thanks!
  2. ChapmanF
    19,019
    DAM0 and SFO like this.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    How many miles/kilometers on this gen2?
    Curious if you had any ideas on why this ECU/relay component failed?
    Do you turn the steering wheel from lock to lock? (like when making a U-turn)
  4. DAM0
    DAM0 Junior Member
    26
    Looks like time to get another PS ECU. Thanks so much for clearing that up ChapmanF!!!
    Mine has 289,XXXKm on it.
    No idea at all why it failed, I assume just normal relay failure after so many tens/hundreds of thousands of duty cycles.
    I often do turn lock to lock when the car was functioning as normal, but since the failure I have not. It should be able to, just very heavy on the steering input required.
    DLC82SV and SFO like this.
  5. DAM0
    DAM0 Junior Member
    26
    Just an update, all fixed with a new (second hand) PS ECU :)
    For anyone interested about the internals, I donated my old one to my tools in the name of science ;) 28169540_1924673047551736_175164925_o.jpg 28053634_1924672894218418_981729633_n.jpg
  6. DAM0
    DAM0 Junior Member
    26
    For anyone wondering, the Omron g8se-1a4 225ohm relays used are pretty available aftermarket, looks super annoying but doable to replace the relay on the PCB. Might have to become a common solution once these cars are a bit older.
