06 wind whistle?
Discussion in 'Gen 2 Prius Main Forum' started by Intuitionx2, Mar 13, 2026.
  1. Intuitionx2
    Intuitionx2 New Member
    usa
    Driving hwy speed getting wind whistle. Can't find a post to known issue. Having trouble locating source. Any traveled this path start points?
  2. Hayslayer
    Hayslayer Active Member
    534
    325
    Yeah, several times. It's usually due to the black plastic trim at the rear of the front door windows. Take some tape and cover it vertically so half the tape is on the glass and half is on the black plastic. Take it for a drive and see if the noise goes away. I did some cars by using the wide blue painter tape to cover the joints until I found which was making the whistle. Cured the noise every time, so at least the source was found. Eliminating it? A bit more complicated, unless your plastic is getting loose. May just need to seal any gaps.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,040
    943
    Southern California
    How long has the OP had that car? If it was a recent purchase check the front for deer whistles.
  4. Intuitionx2
    usa
    Not long but no deere whistles.
  5. Intuitionx2
    usa
    Thanks. The tape is a good way.
