06 would not go in gear-red light in middle of power switch, Brake light on.
Discussion in 'Gen 2 Prius Main Forum' started by bogeybob513, Dec 28, 2009.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    First time this ever happened to me-brake light on, red light in center of power switch. Car would not go into R or forward positions. Emergancy brake was not on, but brake light was on. Finally put the brake on, then off, and it finally went into gear. Brake light switch malfunction?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    You might want to post this in the Gen II forum. This forum is for 2010 and later.
    The brake switch is the most likely culprit. With a 2006, it is also possible that your 12V battery is getting weak.
    Tom
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  4. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
  5. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I have scan gauge and the 12Volt is OK-must be the switch, although I rarely use the parking brake. Thanks for the input.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The parking brake won't stop you from putting the car in gear or starting it. It WILL fire off a buzzer if you try to drive away with it engaged.
    The switch on the main brake pedal WILL dramatically effect whether or not the car will go to "ready". It's adjustable. Perhaps it's loose, or perhaps it's worn to intermittent.
  7. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    I have an 06 Prius that lets me backup with the emergency brake still on with no audible warning. Does turning off the reverse beep also disable the emergency brake warning buzz?
  8. David Beale
    5,963
    1,981
    Edmonton Alberta
    I don't think it disables the warning, but as I recall the warning noise doesn't occur until you actually get moving at a few MPH. I only did it once (so far ;) ).
    Pearl's reverse beep is disabled and the brake warning still sounded (in "D").
