07 Prius 15k service....$139.00!!!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tekn8, May 9, 2008.
  1. nthach
    nthach New Member
    174
    PP is cheaper at $4/quart or $20/5 quarts.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,329
    CA
    I've never seen PP 0w-20 at Walmart.
  3. resoh02
    resoh02 Member
    140
    Northern OHIO
    I almost think the costof the parts and maintenace wipes out the savings for the fuel. Sparkplugs are 65 each, headlights 300each, I had to sync up the tire pressure sensor 80. Maybe all auto dealers are the same but it just seems everything is very expensive. An oil change for the 2010 is 80 to 85. WOW. because of the 0-20 oil.
  4. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Now I am glad I got the Service Plan! :) It's clearly spelled out and it will cost me no more than 1097.00 over 4 years and 60,000 miles.
    Other than a repair if needed....but all normal maint is covered, including wiper blade replacements every 8 months. So that equates to about 274.00 per year. That's reasonable in my book. :)
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you pay that much for any of those items you are getting shafted and not doing your research. :eek:
  6. andrewthebassist
    andrewthebassist Junior Member
    Chicago
    I wanted to thank you for posting this. I bought a used 08 a little over a month ago and the dealer's website said for the 45k package it was $182. I went in and said "I'd like an oil change" and it ended up at $34 (with all of the same "courtesy" checks as the "maintenance package"...).
  7. richard schumacher
    7,664
    1,044
    United States
    All the regular maintenance required is given the in the Warranty and Maintenance Guide:
    http://smg.toyotapartsandservice.com/guides.php
    That's eight oil changes, tire rotations, inspections and a couple of air filters. $500 would be a lot for that. Even less if you change the engine and cabin air filters yourself, and skip the tire rotations.
