07 Prius cruse control resume only works sometimes
Discussion in 'Newbie Forum' started by 07charles, Oct 9, 2016.
  1. 07charles
    07charles New Member
    Georgia
    The cruse control resume function only works sometimes. Does anyone know a fix for this problem?
  2. JC91006
    16,937
    8,647
    Does the air recirculation button work?
  3. 07charles
    Georgia
    Yes
  4. goldarrow
    goldarrow Junior Member
    Los Angeles area
    Possible bad brake light switch...
  5. JC91006
    16,937
    8,647
    Bad brake light switch will normally have a code
  6. goldarrow
    Los Angeles area
    Yes, I had same symptom while back and ran techstream and found the code pointed to bad brake switch. Swapped out the switch with a new one, problem solved. Of course I forgot what the code was
  7. 07charles
    Georgia
    Thanks everyone.
    I will check out the brake switch to see if this resolves the problem.
