07 Prius/Strange dash noises/video
Discussion in 'Gen 2 Prius Main Forum' started by Scott56, Dec 19, 2017.
  1. Scott56
    Scott56 Junior Member
    40
    27
    Alabama
    This is a strange noise that comes from my 2007 Toyota Prius in both driving and in park mode. The audio needs to be turned up very loud to hear it and it sounds like it is coming from under the center dash console. It only does it in cool to cold weather and it happens only about once a week and has not progressed into how often it happens. It doesn't affect any parts of the car. I'm just trying to find a diagnosis for it if anyone has had similar noises. In the summer, there is a louder repetitive clicking kind of sound, which I will post later once I hear it. It only seems to do it in hot to warm weather perhaps on a once a week basis. I switch the damper from defrost to another setting and it resolves the clicking sound for an undetermined time, but the damper switching does not resolve this small barking kind of sound. The barking sound has been related to brake actuator issues, but the dealership did a brake check (and I mentioned specifically to check the actuator) and they didn't find anything wrong with it. It had made this barking sound in the video maybe a couple times before they checked it.
    49,500
    sounds like the actuator, but may not have progressed enough to throw a code.
  3. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    could it be the disc player? have you inserted something or is something half way lodged into the indash player
    49,500
    or maybe the coolant storage tank pump?
  5. JC91006
    16,482
    8,400
    That's a 3 way coolant valve that's about to go bad. When it goes bad, you'll get the check engine light. It's much louder if you open your hood and hear it outside. Code p1121
    If you're in a CARB state, there's a warranty on it for 15 years/150k miles
  6. bisco
    49,500
    hopefully scot is still tuned in after 9 months
