07 Prius won't run ABS pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by William22, May 13, 2025.
  1. William22
    William22 New Member
    Illinois
    Hello!
    We finally replaced the ABS pump after a few weeks of it running constantly. We replaced the pump and bled the brakes and we are absolutely sure there is no air in the lines. Now the car won't run the pump and will constantly whine about low pressure. If you manually instruct the motor relay to run the pump it will build pressure and ABS functions perfectly. Is there any known reason why the car won't run the pump?
  2. saneesh8
    saneesh8 Member
    217
    Allen, TX
    Replaced with OEM or a used one? I read that the used one's randomly get this issue. Any way to scan and post codes?
  3. William22
    Illinois
    It was a used one unfortunately. However, there are no codes except for the accumulator pressure fault whenever the pump randomly decides not to run.
  4. Tombukt2
    Tombukt2 Senior Member
    13,523
    2,434
    Durham NC
    You're replacing just the pump here are you replacing the ABS actuator assembly? There's no reason the car won't run the pump check and see if the pump connections are getting power just because I imagine when you if you're changing just the pump I mean the minute you assemble the pump and plug it up it's going to come on because there's no pressure it's going to try and satisfy the accumulator pump up the system as it needs to be but if it can't stay that way pumped up in pressurized usually it's not the pump that's causing it to not be able to stay pressurized it's the pressure vessel is compromised which is the round black thing next to the pump but what do I know or there's an internal leak inside of that big aluminum block that the lines connect to usually it is referred to as internal not like something leaking at a wheel cylinder or a caliper so if you're just replacing the pump you may be I'm not moving very much forward I guess I would say hard to say because I'm not sure what you've done usually when you replace this assembly it's the actuator you say pump so you're replacing just the silver thing on the big aluminum silver block that the brake lines connect to but not the black round diameter?
    saneesh8 likes this.
  5. William22
    Illinois
    I'm sorry, I was using the assembly and pump interchangeably. We replaced the whole assembly and it won't build up pressure. Using a scanner we have been able to manually turn on the relay to build pressure which will then allow ABS to function normally. After testing ABS, the car seems to recover pressure its lost but will not attempt to rebuild any after sitting and starting again.
  6. William22
    Illinois
    Basically, if you function as the ABS ECU you can drive the car just fine. However, the car refuses to run the pump.
  7. Tombukt2
    13,523
    2,434
    Durham NC
    So then I guess internally that ABS actuator assembly that you've installed is not sensing its pressure wild I've never heard of such a thing but I guess anything is possible or that's what it would seem unless there's an external something that's reading that pressure and then sending signals back to the break actuator I guess that's possible I have to go dig in the manual and see what it says and you have no break codes?
  8. Tombukt2
    13,523
    2,434
    Durham NC
    I know it might be tough maybe you can do it with the heat gun or something is the pump getting excessively hot when it's running you know an electric motor pump etc if it gets right warm it might not come on until it cools off again of course why it's getting warm is an issue obviously and then this could be internal and it could take quite a while for you to be able to notice it on your temperature gun or with your fingers just seems odd you can put power to it and it comes on fine and pumps up well as far as we know or until it shuts off and then you apply the brakes a few times and it won't pump back up yeah that's very interesting that would seemingly be something to do with that big plug on top of the unit and the internals of the actuator it would seem like to me I've had a few bad actuators but not a problem where the pump won't come on usually the pump will run into Oblivion
  9. William22
    Illinois
    Whenever it's low on pressure it will beep and show codes. If you turn on motor relay 2 and run the pump it will function just fine meaning it can read the pressure. I am stumped here.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,907
    877
    Southern California
    Aren't there two relays under the hood somewhere which are needed for the pump to run? Maybe one of them failed. If they were pulled out at any time when the ABS unit was replaced perhaps one wasn't put back in the right slot?
    Tombukt2 likes this.
  11. William22
    Illinois
    Yes, but I can manually turn on those relays and run the pump that way.
  12. Tombukt2
    13,523
    2,434
    Durham NC
    Yes the two blue ones one at the top and one at the bottom of the box they're clearly marked under the hood of the box and they do need to come out from bleeding I wonder if one failed or they're not even put back that would be weird but I guess it's pumping up sometimes oh when they put direct voltage to the pump or something I'm not sure what they're doing.
  13. William22
    Illinois
    I'm using OBD II to run the pump manually.
  14. saneesh8
    saneesh8 Member
    217
    Allen, TX
    If you can do that from the scanner, then electrically it is fine. The ABS ECU should be commanding it to run and for some reason, even though it is detecting low pressure, it does not want to turn on the pump. I assume if there is electrical issue, it should show another code.
    Just curious. After swapping out the unit, did you followed the required steps? Wonder if you are missing one or two steps in between. You used the scan tool to do it and it finished successfully without error? Or did it manually?
    Brian1954 likes this.
  15. William22
    Illinois
    There is no other codes. We did all the required steps, at least as far as I am aware. What would you say are the required steps?
  16. saneesh8
    saneesh8 Member
    217
    Allen, TX
    The steps that the scanner told to follow. Like pump x times, open bleeder valve etc, multiple times. On the Autel MaxAP200 i used, selected the option to do the procedure for unit replacement. It took some time to finish it with 2 people.
    What scanner did you used for this purpose?
    Also, read below. Is it similar or no issue like this?
  17. Brian1954
    Brian1954 Senior Member
    2,462
    987
    South Central PA, USA
    Are there any warning lights on the dash?
    What scanner are you using?
  18. William22
    Illinois
    There is no lights on the dash. I'm using an old Snap On scanner. The brakes are 100% fully bled and everything seems to have been done perfectly. I can relate to their issue of brake fluid not coming out of the rear but the car functions just fine when running the pump. We got the car up to speed to test ABS and the brakes felt responsive.
  19. William22
    Illinois
    I also have tried their fix and it didn't work for me.
  20. saneesh8
    saneesh8 Member
    217
    Allen, TX
    The snap on scanner, does it have a dedicated function to perform the brake bleed after abs unit replacement? Seems it is capable because you can run the pump manually from it.
    Really strange what is happening.. no error codes. It senses it and throws error, but just simply does not want to command the pump to run and the pump can be commanded from the scanner. So software/hardware part is fine for this. Some logic inside the firmware does not want to command the pump.
    I know it is hard, the old one, was running continuously right? but it was building pressure. Can you swap it with old one and see if it is working? Just to rule out any procedure / connection or electrical issues.
