07 Prius won't run ABS pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by William22, May 13, 2025.
  1. William22
    William22 New Member
    Illinois
    The old one was running continuously but nothing else has changed since then except for the pump. The scanner does have a procedhre for it but it wasn't the best. However, I don't think that could have caused this issue. Swapping back the junk pump to test if it is more junk seems like more trouble than it's worth. I think we are just going to get a brand new OEM pump.
  2. saneesh8
    saneesh8 Member
    222
    Allen, TX
  3. William22
    Illinois
    We did order the actuator unit already. I don't know if a different scanner could help. I really think it's just a bad actuator ECU unfortunately. Thank you for your help!
    saneesh8 likes this.
  4. saneesh8
    saneesh8 Member
    222
    Allen, TX
    Update the forum once you replaced it. Very high chance that it is the actuator it self.
