07 steering wheel controls don't illuminate
Discussion in 'Gen 2 Prius Audio and Electronics' started by repnatl, Dec 23, 2017.
  1. repnatl
    repnatl Junior Member
    49
    24
    US
    On my 07 I noticed my steering wheel controls don't light up. I've tried two known working sets and they don't light up either. I have changed my radio out and don't have the steering wheel radio controls hooked up but the hvac and info buttons work fine. I did change out my MFD for a navigation MFD I don't know if that makes a difference or not. Only issue really is they don't illuminate on the steering wheel. Any suggestions?
    52,575
    check the dimmer switch.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Check the clockspring next; common failure point.
  4. repnatl
    49
    24
    US
    No issues with the dimmer all other lights work with the dimmer.
  5. repnatl
    49
    24
    US
    Not showing any signs of a bad clockspring. No airbag light or strange noise as if it's broken like on most I've replaced. I can grab one from another prius next time I find one in the yard but no other issues besides no illumination.
  6. bisco
    52,575
    what is the source of the steering wheel illumination?
  7. repnatl
    49
    24
    US
    That's what I'm trying to figure out I'm swapping the oem radio back in now to see if it solves the issue.
  8. repnatl
    49
    24
    US
    The illumination is controlled by this plug on the back of oem radio that. This is where the steering wheel control wiring is. Well got it figured out just need to do some wiring lol
    SFO likes this.
  9. Dnc95
    Dnc95 Junior Member
    SoCal
    What was the wiring you did? My steering wheel lights are off too but I bought my Prius used with an aftermarket deck. Thanks for the help.
  10. repnatl
    49
    24
    US
    This is the diagram I used since I have an android head unit and found out I didn't even need the aftermarket steering wheel controller because it was built into the android unit. Got lights and controls working now.
    SFO likes this.
  11. repnatl
    49
    24
    US
    As far as the lights are concerned just ground the red wire #6 to the ground wire on the back of your aftermarket radio.
    SFO likes this.
  12. Dnc95
    Dnc95 Junior Member
    SoCal
    Wow very nice, thank you
  13. R-P
    R-P Active Member
    808
    288
    Netherlands
    Did you actually try this and confirm it works?
    Thanks @ repnati. Can't check this today, but will try this soon! Have you had this issue and fix it with this? Sounds logical, but ! have googled this before and never found an aswer (apart from clockspring), so love to have an extra confirmation this actually works between now and when I can actually try it...
  14. jackmilas
    jackmilas Junior Member
    60
    Wrocław, Poland
    I'm using Axxess aswc-1 and I lost the backlights on my steering wheel after installing it.
    The buttons work with my aftermarket Sony, just the lights on the steering wheel stopped working.
    Any solutions?
