07 with Check Engine Light about solenoids
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cibelly Aguiar, Jul 6, 2018.
  1. Cibelly Aguiar
    Cibelly Aguiar Junior Member
    59
    Boston
    Hello everyone!
    The other day I was driving the car normally and a check engine light just popped in my dash. I don't have a computer to read the codes, so I took it to my mechanic and he said that it was a code for a problem with the solenoids, but he doesn't know if it's both of them or just one, and if so, he doesn't know which one because he didn't have time to check them and checking it would take at least 2 days, which is really complicated for me because I only have that car to do everything.
    He gave me a quote for 353$ if he has to change both. My question is, and after some research, I couldn't get a satisfactory answer, are these solenoids really important or can I postpone the fix for a little while? And is there one that is "more" important than the other and with the unknown issue, can they fail on me and bring problems that are more serious?
    Thank you, your help is much appreciated!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    What was the code he pulled ?
  3. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    The only solenoid I know of in the Prius is the variable timing solenoid about $50.
    iPhone ?
    52,841
    just keep driving her, it won't be an issue.
  5. JC91006
    16,936
    8,647
    The check engine light can be caused by a few common problems on the prius. There are codes the car stores that will point you to the problem. You can try going to an auto parts place and have them read the codes for you. That mechanic with the solenoid response isn't making much sense.
    Common things that will cause check engine light are emissions related
    1. Bad/missing gas cap
    2. Bad 3 way coolant valve
    3. Bad catalytic converter
    4. bad oxygen sensors (I think this is what the mechanic is pointing to)
    You should check the emissions warranty in your state, some states that follow California emissions standards will warranty emissions components for 15 years/ 150k miles
    Raytheeagle likes this.
  6. Cibelly Aguiar
    59
    Boston
    I don't know the codes he pulled, but I used an OBD2 device I have and read the codes.
    As you can see in the picture:
    Stored codes: P0446 Evaporative System Vent Control Circuit
    Pending Codes: P0441 Evaporative Emission System Incorrect Purge Flow
    P0446 Evaporative Emission System Vent Control Circuit
    What should I do? Thank you!
    EDIT: The solenoids the mechanic talked about changing were Purge Solenoid and Vent Solenoid.
    #6 Cibelly Aguiar, Jul 7, 2018
  7. Cibelly Aguiar
    59
    Boston
    I don't know which ones he pulled, but using my OBD2 device, I pulled those:
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    In the big scheme of things....no and yes. It's part of emissions controls but should have no impact on driveability and no effect on engine emissions.
    What should I do?
    If it were me? I would just continue to drive the car as per post 4. I would also take the advice of post 5, because Mass IS a carb state and if the car was originally purchased there, it may be covered under warranty.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    You checked your gas cap and the o-ring there to see its condition?
    JC91006 and Cibelly Aguiar like this.
  10. Paul Schenck
    524
    307
    Fresno, California
    I drove mine getting 50mpg for months until I decided to do the repair.
    iPhone ?
    Cibelly Aguiar likes this.
  11. Cibelly Aguiar
    59
    Boston
    The things is that mine is doing around 25mpg since January, and I've been trying to fix that since then and I can't find the problem!
  12. Cibelly Aguiar
    59
    Boston
    Seems to be normal, but tomorrow I'll and a picture of it, just in case!
  13. Cibelly Aguiar
    59
    Boston
    I am thinking about taking the car to the dealership so they can diagnose the problems. Is it worthy?
    And I've been thinking about taking the car to another mechanic so he can help me find the reason for the codes. My biggest fear is that the problem might be catalytic converter, as my dealership quoted me about $2000 to replace it...
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’d root around to see if there are any vacuum leaks or things misaligned causing air to be sucked in and throwing the codes you have.
  15. Cibelly Aguiar
    59
    Boston
    That's what I'll do, on Monday I'll go somewhere else to see if they find something that can be triggering it. This mechanic that told me about the solenoids always gives me the wrong diagnose about the car. But here in the Boston area, besides dealership, is hard for me to find a mechanic that has an understanding of hybrids.
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    @bisco has his work done down the street at a mechanic. Maybe he could recommend someone(y).
  17. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    If it were the converter, there must be a p0420 code
  18. Cibelly Aguiar
    59
    Boston
    That is a relief lol! thanks!!! :D
  19. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You didn't also state the mileage on your car, perhaps that might help to know if you've done your normal maintenance.
    Replacement of spark plugs, EGR cleaning, and all that. Also check your air filter in the hood.
    Lastly, y not get a tech stream to scan the car and have access to the car's HV system? Could be that you have a p0a80 hybrid pack weak logged in PENDING.
  20. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    25mpg since January is dreadful. Can you describe your typical daily driving pattern?
    Do you own an android phone?
