07 with Check Engine Light about solenoids
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cibelly Aguiar, Jul 6, 2018.
  1. Cibelly Aguiar
    Cibelly Aguiar Junior Member
    59
    Boston
    So, I replaced the spark plugs two days ago, one of the was loose, what made me think that it could be generating some problems (I was smelling fuel, the smell was coming out of the A/C vents and would only go away if recirculate mode was on).
    The air filter was replaced in January, both the hood one and the glove box one. The oil was changed on the same day. The car has 175,000 miles on it. By the Toyota Owners website, the last visit to the dealership was at 165k in 2016. I got the car as present from my parents June/17. Before that, the car was with my brother, and he didn't mention any problems...
    I only have an OBD2 scanner, does that work? And if it does, the codes I got are on a screenshot up in the thread. If it is not the same, do you have any recommendations?
    I don't if it contributes to the problem, but I heard that it can be the 12v battery, but I tested using the screen turning on the car with foot of the brake and the information I got was that the battery has 12.3v...
  2. Cibelly Aguiar
    59
    Boston
    I graduated in June, so it changed a bit. Before I used to go to school, which is 3 miles away. Then to work, which is about 3 to 4 miles from school. And go home later another 3 miles. Usually, I go to church at night too, so 12 miles going and coming back. I would say 80 to a 100 miles weekly. Now it's just work and church, besides going shopping and stuff.
    I have an iPhone.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    If you have an android phone, you can use an OBD bluetooth adapter and some free prius/hybrid apps to communicate with the car and be able to read the hybrid specific codes.
    Cibelly Aguiar likes this.
  4. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Another issue you may be experiencing is that the first 5 minutes of operation is basically warmup time for a prius. My mileage for the first 5 minutes is typically around 25mpg. If all you do is very short trips, its going to be difficult to get better mpg.
    There's a thread somewhere on the forum that describes the 3 or 4 operating modes of a Gen 2. The first 5 minutes is the worst for mpg due to warm up programming.
    Maybe you could take the car for a 25-30 mile drive on the highway, after warm up, to see what kind of mpg you see?
  5. Cibelly Aguiar
    59
    Boston
    I have an OBD2 Wi-Fi scanner. A Kobra ELM 327 that I used with an app called dash command, I don't if it is a good app, but I scanned and the only codes showed were those (in the screenshot).
    Is there a way to have more codes stored that the app wouldn't show me?
  6. Cibelly Aguiar
    59
    Boston
    My total mileage since the last fueling (I wait till the last blip to refuel completely), was 140 miles. Is that because of the short trips?
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    My gut feeling is that something isn't quite right with your car, but not being there makes it difficult to make an accurate assessment.
    On my gas gauge, I usually hit 140 miles and still have 8-9 blips showing. Then somewhere around 210-230 miles at the half tank mark.
    Are you typically putting in 7-8 gallons when you refill?
  8. Cibelly Aguiar
    59
    Boston
    7 gallons and a little bit. $20 with the gas at $2.84
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I am totally unfamiliar with that app. I googled it but didn't see anything about it being able to read hybrid codes.
    Just to clarify, you only have the check engine light? No triangle?
  10. Cibelly Aguiar
    59
    Boston
    Do you know if there's at least one that I can use with a computer with Windows? My family and friends all use iOS :/
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Has your mechanic checked for fuel leaks? I can't imagine any prius, anywhere, under any condition that would burn 7.x gallons in 140 miles without having some significant codes being thrown. UNLESS, there is a pinhole leak in a fuel line. What does your MFD show for mpg calculations while driving?
  12. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Unfortunately, I also have an iPhone. I acquired a Galaxy S5 that I use exclusively for my Prius apps.
    You can purchase a mini-vci cable on ebay that connects your laptop/computer to the obd port . It will come with a disk to put software (techstream) on your computer to allow communicating with the car. Typically around $40. Some versions are for 32 bit computers, some also work on 64 bit/windows 10.
  13. Cibelly Aguiar
    59
    Boston
    I was trying not to buy another phone haha. I have a spare computer that I may be able to install Android on it. Do you think it will work? And secondly, with what device would test the Hybrid battery?
  14. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    An android phone with Hybrid Assistant/Hybrid Reporter apps can be used to load test the HV battery using the air conditioning compressor or by using "reverse" on the transaxle.
    There are many many apps available for android phones to work with Prii. Androids are cheap on ebay.
  15. Cibelly Aguiar
    59
    Boston
    So I don't need a device connected to the OBD2 port?
  16. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    yes, you will still need the OBD bluetooth adapter. The one you currently have may be good enough. Some apps have recommended adapters, but most will work.
    I use an OBD Link LX, mostly because that's what was recommended by the app designer
  17. Cibelly Aguiar
    59
    Boston
    Do you have any recommendations on one?
  18. Patrick Wong
    18,210
    6,517
    May I suggest that you reset the mpg indicator on the MFD. Then take a long drive of at least 100 miles round trip on relatively flat terrain, going at speeds of 50 - 70 mph, and see what mpg is registered by the MFD. Report that finding.
    You cannot expect to log very good mpg if you drive 3 miles at a time. Also, it was not helpful that you had one loose spark plug.
    Back to your post #7 and the DTC associated with the fuel tank, that is a repair that eventually should occur if you need to pass emissions control testing. Do you actually smell gasoline vapor either in the car or as you walk around the car?
    Raytheeagle likes this.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    #1 reason for poor mileage is an aged hybrid battery. At your mileage its a given. think your seeing the first signs of hybrid battery death. Your ELM will not decode hybrid battery codes.
    Cheapest and easiest OBD right now is the VXDIAG on Amazon for $77. You want the one with Toyota Techstream V10. $77.
    USB plugs into a laptop.
    #39 edthefox5, Jul 8, 2018
  20. bisco
    52,841
    anyone wishing to help the o/p would do well to read through past threads for a more complete picture of the situation.
