08 headlight or ballast
Discussion in 'Gen 2 Prius Technical Discussion' started by dalen, Aug 2, 2014.
  1. dalen
    dalen Junior Member
    My 08 passenger side HID is intermittingly on and off and at times grows dim but stays on. Reseaching, I think it s either the HID bulb or the ballast. How do I tell which one? I have already had the driver side HID replaced last year-$$$$-so I am thinking of doing the work myself. The bulb is within my abilities but if it s the ballast I m a little hesitant. Thanks everyone.
  2. Patrick Wong
    18,200
    6,492
    The bulb is most likely at fault so you should start by replacing it.
  3. James2005
    James2005 Junior Member
    Maryland
    Not to hijack your thread, but I had a similar issue. Noticed one of my headlights (passenger side) would not come on at start-up and had to toggle headlight switch to get both headlights to work. I replaced both bulbs with these from Amazon
    and things seemed perfect for the first week. Now I have issues with both light, only 1 will work at start-up (some times it's the passenger side some times it is the driver's side). And I usually have to toggle the headlight switch multiple times to get both lights to work. Very annoying.
    Don't know if I should purchase 2 more bulbs and hope that the first 2 were somehow bad or attempt to replace the ballasts.
    James
