'08 Heater - Warm But Not Hot
Discussion in 'Gen 2 Prius Main Forum' started by hybridgrl, Feb 3, 2008.
  1. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    I had a -20°C (-4°F) commute the other day too. My coolant temp actually got to 70°C (just under 160°F), with 80% grille blocking. That made for a comfortable 25 MPH drive on the icy highway.
    When the temperature climbs to just under freezing, you can melt stuff with the heater... which is why I choose not to block completely. The heat is always set at MAX HOT with the blower somewhere at a middle speed and no recirc.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yes, block the grille and heater performance is much better. Do *not* block the radiator itself, that is very dangerous
    I also block the grille on my FJ as it really makes a difference in heater performance, especially -30 C and colder
  3. M A azim
    M A azim Junior Member
    Winnipeg, MB
    I am having same problem with mine
  4. jrw1621
    jrw1621 Junior Member
    Huron, OH
    Is your mpg down in the 30's also? If yes, it is a bad engine thermostat.
    Without the thermostat working properly, the engine never builds enough heat to make the car warm inside.
    Not a complex fix. Any mechanic can fix it. It's not even a Prius specific part. The same thermostat is used in the Camry and more.
  5. jrw1621
    Huron, OH
    Someone else's video on the topic of replacement.
