08 Prius 148000 Miles Issue with Startup
Discussion in 'Gen 2 Prius Technical Discussion' started by Chisox1976, Nov 13, 2018.
  1. Chisox1976
    Chisox1976 New Member
    Chicago
    Okay so let my start by saying what happened. I was doing uber and everything was alright with my car. The Oil change light was on but I know I don't need an oil change. So I went and got gas at the gas station and when I went back in my car to start it, I heard my phone vibrate but then everything went completely Dead. Everything. I thought it was battery and was just sitting in my car when the car just started up. I really didn't do anything. The next morning, it didn't start right away but I got it too and it ran fine for a few more hours. I also didn't notice anything wrong. I drove to my job on Monday and no problem. Then went in the car today and nothing. The check light (the bad one I think) came on.
    Okay, a couple other things the key fob only worked when you put in the slot and couldn't lock it through the fob. Also, I checked the cap on the gas, heard that might be something but it clicked and couldn't come off. I haven't jumped it in a year or two. I think I have given all the information. Could this be just a blown fuse or issue with the 12 V. Again it was running perfectly fine. Thanks for any help and if you need any other information please ask. Also does this sound like a problem with the power invertor. I think thats what it is called.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    The 12v is always the easiest and one of the least expensive things to check. Start there.
    52,849
    get a voltmeter and test it at the jump terminals after it has been off for at least 4 hours.
    btw, there is no 'oil change light'. not sure what you saw
  4. Skibob
    2,912
    1,505
    Northern California
    Come on bisco, you know what light he is talking about. “MAINT REQD”. “Engine oil reminder light (for vehicles sold in USA)”
    It’s in the owners manual. Page 6 in the 2006 one. :cool:
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    If the 12V checks OK under the hood at the test points, I would next check the battery itself for loose connections at the terminals and check the ground wire where it connects to the body of the car near the right tail light.
  6. Al Bundy
    Al Bundy Member
    140
    69
    florida
    theres a button under the steering column to turn on the keyless system... (if you mean this fob issue just started) you may of hit it with your knee..
