08 Prius Dead. 12 v battery and spare tire under Ice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cheeper, Feb 21, 2015.
  1. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    If you cannot pull it upwards it is not going to move much. Perhaps some luggage straps might do the trick if you can find somewhere to hook them.
    John (Britprius)
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I was going to say, it sounds pretty secure to me.
    Besides, it's packaged pretty low down, right?
    Not likely to have a trajectory into the passenger compartment.
    cheeper likes this.
  3. cheeper
    cheeper Member
    154
    Greene Co, NY
    It seems Solid; no movement. Will see If I can secure it from bouncing up. Back to those directions.
  4. cheeper
    cheeper Member
    154
    Greene Co, NY
    Concerned would it bounce, disconnect or ???
  5. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I don't think so. Many car batteries just ride around on their trays with no ill effects.
    In the long run (after the weather gets warmer) you might want to go back in and do everything nicely. For now see if the car wakes up and works.
    cheeper likes this.
  6. cheeper
    cheeper Member
    154
    Greene Co, NY
    Yes!!! Great concern!!!! Pet that kitty for me. Miss mine; (passed on)!
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Sophie.
    Meet Sophie.
    cheeper likes this.
  8. cheeper
    cheeper Member
    154
    Greene Co, NY
    Sophie! :)
  9. cheeper
    cheeper Member
    154
    Greene Co, NY
    I Did It!!! I Did It!!! THANKS TO ALL OF U WHO HELPED! :) ♥ Car Starts, got that window back up. Can't Thank u enough!!!
    usnavystgc likes this.
  10. bisco
    51,977
    congrats!(y)
    cheeper likes this.
  11. cheeper
    cheeper Member
    154
    Greene Co, NY
    Thanks! :)
  12. Britprius
    5,194
    1,921
    Well done. This may help you to do other work on the Prius yourself without having to spend $$$ at the dealer.
    Keep in touch here you will always be welcome, and helped by a great bunch of people.
    John (Britprius)
    cheeper likes this.
  13. cheeper
    cheeper Member
    154
    Greene Co, NY
    Thanks! U have been Tremendous Help for me! Glad u and priuschat r here. I previously replace rear light section having chipped hole with kayak. There was a Super video on replacing it. Love not spending money! The battery was Scary; too close to the heart of the car.
  14. Britprius
    5,194
    1,921
    You may need to reset the auto close on the drivers window. This is easy.
    Lower the window to about half way, then raise all the way keeping you finger hooked on the switch in the up position for about three seconds. Job done.
    John (Britprius)
  15. cheeper
    cheeper Member
    154
    Greene Co, NY
    Went out and did it, but have never heard of this. I have the most basic Prius and may not have it. I Must Double check Every time I get out of the car to make sure All windows r up.
    Thank you for your wonderful help and Thank you soooooo Much for your patience!!!
  16. Britprius
    5,194
    1,921
    All models of the gen2 Prius have the auto "go to full open/ go to fully closed" drivers window. This setting is lost when the 12 volt battery is disconnected.
    John (Britprius)
    cheeper likes this.
  17. cheeper
    cheeper Member
    154
    Greene Co, NY
    Thanks!!! Good to know!
  18. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Glad you got the new battery wired. (y)
    Did you find the leak that allowed water into your hatch? That should be resolved soon otherwise your HV battery may be in danger. There are posts here about body cracks in our model Prii that allow water to trickle into the hatch area. There are also some DIY remedies to this involving sealants, etc. Check them out. Not something you can do in freezing cold, but if you can get it inside a garage or parking deck with reasonable warmth, you may be able to get it done.
    EDIT: Duh...I see now that you mentioned a cracked window probably led to the water in the back. However, I would still verify that you don't have the body crack that many have reported. It may be due to both reasons.
    cheeper likes this.
  19. cheeper
    cheeper Member
    154
    Greene Co, NY
    Thanks!!! I will keep an eye on it!
