08 Prius Issues P0AA6 C1378 C1241
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robbie T, Sep 7, 2019.
  1. Robbie T
    Robbie T Junior Member
    Oahu,Hawaii
    I have a 2008 Prius with a reconditioned hybrid battery and a new 12 v battery that i have test myself.
    The car get red triangle,ABS and VSC warning lights randomly while driving and it will continue to drive fine until you turn it off then it will not go into drive.To drive the car again I have to disconnect the positive battery cable (only tried positive because ease access) and unplug the 2 connectors that are plugged into the positive cable then after reconnecting the positive cable the will drive fine for 2 feet or 2 days and the same thing happens and to get going repeat the process to drive the car.I took it to Oreilly's and got thes codes
    P0AA6,C1378,C1241.Im in Oahu to help my Daughter get this solved by next Saturday.
    Thanks
    49,694
    welcome!
    check the inverter fluid reservoir for movement with the car ready.
    how many miles on her?
    you can find code troubleshooting in the service manual at techinfo.toyota.com
    all the best! (y)
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    The OBD2 reader offered at the parts shop doesn't read the associated INFs (subcodes) for one of the retrieved DTCs.
    ** Notice that DTC P0AA6 (aka P3006) has five (5) different INFs, and these can help narrow down the issue faster.
    ** Here is the work up for DTC P0AA6 with the five (5) associated INFs : https://attachments.priuschat.com/attachment-files/2018/04/145252_2006_Prius_RM_-_P0AA6.pdf
    Here is the work up for DTC C1241 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/21avn/cic12414.pdf
    Here is the work up for DTC C1378 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/21avn/cic13784.pdf
    Raytheeagle likes this.
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    You have a HV leak to the body chassis of tr car, that's y you got that code.
    You need to get the car scanned or read for trouble codes, to narrowed foen the problem.
    The car shuts down and refuses to start, at every time you put the car off, because of the ECU on the car, pretty much dees that there's a risks of electrocution.
  5. Robbie T
    Oahu,Hawaii
    Thanks for the replies-Im working on solving the issues now. I have a scanner recommended by members here -the ELM327 It will be here on Tuesday.
    The car has 145,000 and there is good movement in the cooling reservoir.
    Im ging to look at the HV battery next and check the connections.
  6. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Hope you picked up a mini-vci cable with techstream, which will allow you to read any subcodes (INFs) for reported DTCs.
    Skibob and Raytheeagle like this.
  7. Robbie T
    Oahu,Hawaii
    Well the ODBII reader I ordered did not read the sub codes.I ended up taking it to a shop specializing in Prius as well as other hybrids and they tested it tracked it down to the HV battery having a leak of bad cells or both.I do not have the codes from them yet but will have them tomorrow.I am taking the car back to the shop that replaced the battery back in February .
    I will update this as I get the information.Thanks again for tall the members who have posted here to get me to this point.
  8. Robbie T
    Oahu,Hawaii
    There were 2 bad cells in the Hybrid battery and they working on the car now.Im thinking of buying a new battery from newpriusbatteries the next time I have issues with this battery.
  9. Robbie T
    Oahu,Hawaii
    The original shop replaced the 2 bad cells and car runs normal as now -I will keep everyone updated.
