08 Prius need help with codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yotagang, Apr 26, 2022.
  1. yotagang
    yotagang New Member
    los angeles
    08 prius has these codes, advice would be apreciated. Thx.
  2. ChapmanF
    15,560
    Say, what app is that?
    It looks like it has freeze-frame buttons. Have you checked those?
  3. yotagang
    yotagang New Member
    los angeles
    Its a walmart bluetooth scanner its called Autel and yes it has freezeframe data. Havent checked as neighbor only had time for me to check codes.
    49,430
    you need a battery
  5. yotagang
    yotagang New Member
    los angeles
    They already changed the battery with a used one, guess its no bueno? How about the cam code? is it related to a bad battery ?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,454
    1,501
    NJ-USA
    Hmmm. Autel MaxiAP200. See a number of complaints about the app having connection problems. But Autel makes scantools that have pretty good functionality for the price.
    I will have to check this out.
  7. bisco
    49,430
    not sure about the cam, because of the scanner. but most will pick up a bad battery.
    who changed it? what did they put in? how many years/miles ago?
  8. yotagang
    yotagang New Member
    los angeles
    30k miles ago. Has only 130k miles. A used battery. Shade tree mechanic.
  9. bisco
    49,430
    there's just no way of knowing for sure, without sub codes. but a used battery is a risk.
    a 2008 with 130k is just broken in. if it is the battery, i'd put a new one in, or cells from 'newpriusbatteries.com'
    yotagang likes this.
  10. bisco
    49,430
  11. yotagang
    yotagang New Member
    los angeles
    its a little jittery if that makes sense. losing oil and refilling. ill check it out. thx! The thing is it needs to he smogged in about 2 weeks:cry:
  12. bisco
    49,430
    yeah, that's a bummer :(
