Codes P0011 and P0016 ??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by adaddo, Feb 10, 2014.
  1. adaddo
    adaddo Junior Member
    IN
    2006 Prius, 220,000mi. .. just started showing trouble codes P0011 and P0016
    No other symptoms...
    Any suggestions appreciated..
    thx
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Google search reveals possible timing problems, might be due to worn timing chain. Not surprising for a high mileage car such as yours. I would have it checked out by someone who is a good Prius mechanic.
    Google "Prius P0011" without the quotes for more info.
    Sorry I can't be of better assistance on this.
    http://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/2054m/cip0011.pdf
    P0016 Error Code | PriusChat
    adaddo likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    From the 2010 DTC tables, not sure if same for your Gen 2:
    P0011
    Camshaft Position "A" - Timing Over-Advanced or System Performance (Bank 1)
    - Valve timing
    - Camshaft timing oil control valve assembly
    - Oil control valve filter
    - Camshaft timing gear assembly
    - ECM
    P0016
    Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
    - Valve timing
    - Camshaft timing gear assembly (for intake camshaft)
    - ECM
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Purely because it is the simplest and cheapest item check I would remove the camshaft oil control valve filter and clean it. This will cost nothing, but a little time.
    John (Britprius)
    wbs887700 and Silver Pine Mica like this.
  5. MCiprian
    MCiprian New Member
    brooklyn, ny
    Were you able to find a resolution for the p0016 code? i have the same error code and have changed all the sensors and no solution.
  6. johnjohnchu
    johnjohnchu Active Member
    212
    105
    After a major engine rebuilt a few years ago, I also started to get P0011 once in a while without any noticeable performance degradation. This usually occurs during a multi-hour long drive in a hot day. Replaced the oil control valve filter once when the code first showed up. I normally just clear the code or sometimes it would just clear by itself. Do not know if this is something that I need to be concerned.
    wbs887700 likes this.
  7. Patrick Wong
    18,210
    6,517
    How many miles on the engine? Was the timing chain replaced during the rebuild?
    P0011 means the camshaft timing is advanced more than 5 degrees from where it is supposed to be, so maybe the camshaft timing oil control valve has an intermittent problem, or the intake camshaft was slightly out of position vs where it should be, or maybe the timing chain stretched, or the VVT sprocket has a problem?
    I guess that if you haven't noticed a powertrain performance problem, then you can live with this indefinitely - if the engine was going to blow up based upon valve interference it has had a few years to do so already.
    wbs887700, johnjohnchu and m.wynn like this.
  8. johnjohnchu
    212
    105
    The engine has 270 k. It was rebuilt about 100 k ago. Timing chain was replaced as part of the rebuilt.
    m.wynn likes this.
  9. wooha2000
    wooha2000 Junior Member
    Is there a video on how to change the "CAMSHAFT TIMING CONTROL VALVE SENSOR".. I have searched youtube and can't find one for a 2007 PRius
  10. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    It depends what you mean by the "CAMSHAFT TIMING CONTROL VALVE SENSOR"
    It seems it could be "Camshaft Timing Oil Control Valve. Was this phrase on a workshop invoice?
    The Variable Valve Timing (VVT) system includes the ECM, the Oil Control Valve (OCV) and the VVT controller. The ECM sends a target "duty-cycle" control signal to the OCV. This control signal, applied to the OCV, regulates the oil pressure supplied to the VVT controller. Camshaft timing control is performed based on engine operating conditions such as intake air volume, throttle position, and engine coolant temperature.
    The ECM controls the OCV based on the signals from several sensors. The VVT controller regulates the intake camshaft angle using oil pressure through the OCV. As a result, the relative position between the camshaft and the crankshaft is optimized, the engine torque and fuel economy improve, and exhaust emissions decrease. The ECM detects the actual valve timing using signals from the camshaft position sensor and the crankshaft position sensor. The ECM performs feedback control and verifies target valve timing.
    If it is the OCV, look up posts by EdtheFox as he replaced one. Some of the time, the OCV just needs the filter replaced.
  11. wooha2000
    This is the part "CAMSHAFT TIMING OIL CONTROL VALVE"
  12. dolj
    dolj Senior Member
    8,646
    4,397
    #12 dolj, Aug 22, 2020
  13. wooha2000
    Thanks for help... this is the hex bolt for the VVT oil Filter 1 inch below "CAMSHAFT TIMING CONTROL VALVE SENSOR"
