08 Prius Shakes
Discussion in 'Gen 2 Prius Technical Discussion' started by richard203, May 3, 2020.
  1. richard203
    richard203 Member
    279
    61
    SF
    hi i was wondering is it normal if you let ur prius idle and it using the battery and then later the engine kicks in it shakes the car for a sec it does that every time the engine kicks in when its idling.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    In some its normal, as long ad there isn't the red triangle light or check engine light showing on the dashboard
  3. richard203
    richard203 Member
    279
    61
    SF
    there is no light on.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Its normal then
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A couple of things that can help: Tuneup (easy) and new motor mounts (not so easy). Also, it's a gen 2 thing.
  6. bisco
    52,662
    if it's occasional, it's usually unburned hydrocarbons in the intake manifold., usually caused by turning the car off while the engine is running. best to try to avoid the situation if possible.
    SFO likes this.
  7. richard203
    richard203 Member
    279
    61
    SF
    i already did the tune up for the engine ( sparkplug, engine air filter, cleaning MAF sensor and throttle body) i did not replace the motor mount tho.
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    The WORST Prius start-up vibration I have experienced is still much less annoying than any of the non-hybrid vehicles I have driven with "auto stop/start", what garbage!
    ydpplqbd and George W like this.
  9. dolj
    dolj Senior Member
    8,630
    4,383
    Wellington, New Zealand
    Another thing that can help (which could also be classed as a tune-up): Reconditioning cycle of the HV (hybrid vehicle) battery.
    While on my car it was not too bad, more of an annoyance, this was one of the things I noticed immediately after doing its first recondition. The car no longer lingered or shuddered when transitioning to ICE off. To date, some four years later, still smooth.
    I am using a HA (Hybrid Automotive) system for reconditioning.
    I wonder if any other reconditioners out there could comment if you noticed the same. Whether positive or negative, all feedback would be useful.
