08 Prius Siver logo smart key stopped functioning
Discussion in 'Gen 2 Prius Technical Discussion' started by saady2s, Dec 16, 2019.
  1. saady2s
    saady2s Junior Member
    22
    Chicago
    Four Touring
    I have 08 prius, smart key fob (silver log).
    I am able to lock and unlock doors with remote but smart entry functionality stopped working all of a sudden.
    Now, my car requiring me to insert fob in car to start.
    What has triggered this to stop functioning like this?
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Checked/replaced the FOB battery lately?
  3. saady2s
    22
    Chicago
    Four Touring
    Battery is not more than 6 months old. But I can replace it.
    lock/unlock button would still work with low battery?
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Could always try a new FOB housing for $10 on ebay.
    Be sure and transfer all of the important bits before tossing out the old housing.
  5. saady2s
    22
    Chicago
    Four Touring
    Wonder what smart functionality has to do with housing of the fob....?
  6. bisco
    52,776
    check the 12v health
  7. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    From your replies, one would assume that you haven't accidentally hit the SKS button under the steering wheel with your knee.
    bisco and davecook89t like this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Go with SFO........
    Definitely sounds like the KEY button on the dash under the steering wheel.
  9. Landon51
    Landon51 Member
    190
    63
    US
    Same thing happened to me and others thoughout the forum. this had happened randomly all to many people. so far there has been no fix.
    I've done a bit of research and haven't gotten anywhere with it.
    if you have techstream, you may be able to re register your keys.
    if you have to re seed your immobilizer ecu, you might be able to re use the current seed within it already.
    i can send you some url'd toother forums that i read - maybe your Google-fu is better than mine. you might find some things that I've missed.
    these are very technical so let me know if you want them
  10. saady2s
    22
    Chicago
    Four Touring
    its good
  11. saady2s
    22
    Chicago
    Four Touring
    I may have. I dont know. How to go about fixing it?
  12. saady2s
    22
    Chicago
    Four Touring
    yes please. I want to fix it. Its very annoying putting fob in every time to start the car. :(
  13. saady2s
    22
    Chicago
    Four Touring
    I installed New battery in fob now. Same issue. Smart functionality is not working.
  14. bisco
    52,776
    the button is under the steering wheel. depress it once to turn on/off, again to repeat
    saady2s likes this.
  15. saady2s
    22
    Chicago
    Four Touring
    SOLVED!
    PRESSED ON THE 'KEY' BUTTON ONCE AND NOW ITS WORKING FINE. SO I GUESS PRESSED IT UNINTENTIONALLY SOMEHOW.
    Thanks for all the help.
  16. bisco
    52,776
    it happens.
  17. bisco
    52,776
    one should never nice person u me :p
    SFO likes this.
