08 Prius Won't Start - Lights still work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jonfen, Jan 10, 2018.
  1. Jonfen
    Jonfen Junior Member
    Detroit
    In the midst of a major cold snap late last week, I tried to start my 08 prius and while my FOB worked to unlock the doors, and I was able to turn the headlights on, the car would not start. Nothing on the dashboard is lighting up aside from a flashing icon that looks like a car with a key inside it. I've tried jumping it from both the front and back with no luck. I thought maybe it had something to do with the severe cold we were experiencing (single digits with below zero wind chill), but it has since warmed up and the car still won't start. Anyone ever encountered something like this?
  2. padroo
    padroo Senior Member
    2,763
    2,253
    How old is the 12 V. battery? I would take the battery to the parts store and have them test it. Check all battery connections both positive and negative. This is always a good starting point. A bad battery can't be jumped very easily.
    52,615
    could be a bad multi info display as well, but test the battery first as padre says above, or replace if original.
    you can also take the battery out of the circuit and try jumping.
    the flashing lock is the immobile which always flashes when the car is off.
    try holding the start button for 4 or 5 seconds.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That depends on how bad and why it's bad.
    Most batteries that are just getting weak will jump very easily..........IF the donor battery really is healthy and fully charged.
    At 0F, it might not have had much strength either.
  5. Jonfen
    Detroit
    Thanks for the responses everyone. I'll start with testing the battery and go from there!
  6. JC91006
    16,893
    8,627
    Have you tried putting the keyfob in the key slot to start the car?
  7. Jonfen
    Detroit
    I did try putting the fob in the slot, no luck
  8. JC91006
    16,893
    8,627
    Did you have the keyfob in the keyslot when you were jump starting it?
    You might have an issue with the combination meter and it's not lighting up when your car is on. Try to jump start it and then after you start the car, wait 30 seconds and see if the engine turns on. If the engine turns on and you don't have dash lights, it just means you have a bad combination meter
  9. 550/440
    550/440 New Member
    Mesa
    I’m experiencing this same exact problem. What was the solution? I can’t roll up my windows and it looks like it’s going to rain tonight.
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    What is the status of your 12v. Can you get a jump from someone?
