09 hazard button wire harness screw up...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nightfly68, May 14, 2020.
  1. Nightfly68
    Nightfly68 New Member
    Ventura Ca
    So I thought I’d be handy and remove my touch screen MFD to get it repaired. I watched videos on u tube seemed straight forward. So I popped my dash apart no prob and only had to disconnect power wires from Back of MDF unit....As much as I tried I could not get the wiring harness to separate from the back of the hazard light component. I accidentally pulled all of the wires and they separated from the plastic connector ! Open further inspection I found the was a release button that I had totally missed. There are 8 colored wires that busted out it the plastic connector and I do not know what the order is. Can anyone tell me the correct order of the colored wires that attach to the hazard button? Or how to find it?
    Thanks!!
