09 Prius - Max MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Gibztr, Jan 14, 2014.
  1. Gibztr
    Gibztr New Member
    I have been searching the web for the best way to increase my mpg in my 09 Prius
    i know that the way i drive has something to do with it. But there is no way to increase my mpg up to 80-100 by driving better so...
    i have also seen chips on ebay but i don't trust those can anybody vogue for those?
    What are some things i can buy or do to my Prius to get better mpg?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Most economical hardware methods to increase mileage are stock in a Prius.
    In Cold weather you can block the grill to keep the engine warmer, and you can buy a block heater to warm it up before you drive. Part of the year this can be a 5 MPG improvement.
    Gen 3 Prius Lower Grill Block - How to with Picture | PriusChat
    Engine Block Heater for 2004-2009 Toyota Prius - PriusChat Shop
    Most of your improvement will be via relearning your driving technique. You might get 10 MPG that way. This can help. ScanGauge II ODB Scan Tool + Digital Gauges + Trip Computers - PriusChat Shop
    ksstathead likes this.
  3. Trollbait
    11,514
    Hypermilers have gotten over 100mpg in the gen2 without any add ons.
    Besides driving style, you try a grill block. This will clean up the airflow a bit, and help speed up warm up times. removing the air box snorkle so warm engine bay air is drawn in will also speed up the warm up time. Some have gone all out on reducing warm up by installing a block heater.
    A Scangauge2 is great for improving your driving style. It gives more info than the car displays, and some instant feedback.
  4. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    See the links in my signature.
  5. bisco
    49,398
    welcome to priuschat!(y) new Lrr's will help, pump 'em up to the max. perhaps a lighter oil? freer flowing air cleaner. eric becky is having an enginer summit, a second battery will make a huge improvement. remove any unnecessary weight from the car including spare tyre and jack. you might try losing a few lbs yourself.:)
  6. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    What mpg are you getting now?
  7. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I agree. Don't buy. Learn and practice! It mostly comes down to driving technique and habits.
    Do you pulse/glide? This thread in ksstathead's sig is a great way to learn:
    Beating the EPA - The Why’s and How to Hypermile - CleanMPG Forums
    Put plenty of air in the tires so they roll better...I use 44 psi front, 42 psi rear.
    I find that not using "auto" on the climate control really helps. Try keeping it off and only using it in manual mode, as needed. In cold weather, it seems to help to try to keep the heater off for the first few minutes of driving to help the drive train warm up.
    A list of tips from Eco-modder:
    100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
  9. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    My wife regularly pulls off 47mpg in our 08. That's pretty solid consider her Flex got 18mpg.
  10. Gibztr
    Gibztr New Member
    I average 38 mpg.
    i'm driving 500 miles a week
  11. Gibztr
    Gibztr New Member
    there is know why i can hyper/glide i have a need for speed i drove my prius very fast and exceled very fast for one day and got 34 mpg instead of my normal 40ish
  12. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    The most important thing in the MPG game is the DRIVER.. I have had more than one Prius owner in my area tell me that they can only get around 38-42 MPG, I have jumped in their car and showed them that it will get mid 50's easy. The car is simply a tool, its all in how a person uses it.
    PriusGuy32, ewxlt66 and ksstathead like this.
  13. bisco
    49,398
    i have read that if you can get it going fast enough, momentum will take over, and your mpg's will start going up. i will look for the link.;)
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Bisco, it might be true in a vacuum, the rest of us spend most of our HP pushing air out of the way.
  15. bisco
    49,398
    well, when the first post indicates goal of 80-100 mpg, you have to think inside the vacuum!
    SageBrush likes this.
  16. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
  17. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Clearly, fuel is still much too cheap where you are.
  18. Gibztr
    Gibztr New Member
    $3.24 currently (last time i filled up)
  19. bisco
    49,398
    needs to be at least 5 to wake up the sleepyheads.:p
  20. dorunron
    3,318
    1,103
    Houston, TX
    IMO, it has to do with the age of the individual. There are those who remember when gas sold for $.39 per gallon (39 cents per gallon) and even cheaper than that. Then there are other's who only know gas prices at the current level.
    Heck, when gas reached $1.00 per gallon I thought it was expensive. At today's prices, it is ridiculous in my opinion.
