09 Prius - Max MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Gibztr, Jan 14, 2014.
  1. bisco
    52,863
    agreed, but it doesn't seem to phase many. when it goes back up to 4, there'll be a lot of whining for a while, and then it will go away again.
  2. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The last time gas was $.39 a gallon was 1974. The last time gas was $1 a gallon was 1990. When adjusted for inflation, both gallons were around $1.50 in today's dollars.
    The 1974 gallon was $1.43 and the 1990 gallon was $1.57 in 2011 dollars.
    Starting from 1929, gas prices bounced around between a high of $2.57 (1934) to a low of $1.40 (1998) in inflation-adjusted dollars and didn't begin to soar above that range until Bush, Cheney, and the early years of the Iraq War 2005+. I think that's actually remarkably stable.
    Vehicle Technologies Office: Fact #741: August 20, 2012<br />Historical Gasoline Prices, 1929-2011 image.jpg
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OP,
    The only 'tricks' I can think of that might help you, an aggressive driver, are the engine heater and pumping up the tyres to sidewall maximum.
    Don't expect miracles though. 38 mpg might turn into 40.
