09 Prius weird noise (with a video)
Discussion in 'Gen 2 Prius Main Forum' started by I love reading, Nov 18, 2018.
  1. I love reading
    I love reading New Member
  2. PriusCamper
    PriusCamper Senior Member
    13,416
    5,416
    Pacific Northwest, USA
    Excellent way to present the noise... Wish others were able to do it so well... How's the health of your 12v battery? Sounds like a pump is not getting enough power.
  3. I love reading
    Thank you!!!LOL!!! I just jump started the 12v battery since it was dead. I drive around my home to test it. It was good. I am not sure it got enough power....What did you think should I do??
  4. PriusCamper
    13,416
    5,416
    Depends on if you've replaced the battery yet... If you haven't you can avoid future hassles by doing so... Don't buy and Optima 12v, they're total junk. Auto parts store will likely sell you ~35amp-hour for $240... But you can get a higher quality 55amp-hour that's designed for wheel chairs and home computer backup power supply battery at Batteries Plus for $140. The mounting terminals are slightly different so you'll need some longer bolts and some bushings from a hardware store to make it work.
  5. bisco
    52,791
    how old is the 12v?
  6. I love reading
    Wow!!!!! That's a lot of information!!!! I will go to Batteries and see!!!
    Can I purchase it at Walmart? The mechanic guys may help me replace it with lower labor cost. I am worried that I do not have such tools and skills to do it by myself.LOL. I will watch some youtube videos. Thank you!!!!!!
  7. I love reading
    I do not know.....I purchased the car in 2014. The deal said they've replaced it with a new one.....So maybe 2014.
  8. bisco
    52,791
    it might be worth charging it up with a proper trickle charge to see if she holds
  9. Aztechmaster
    Aztechmaster Member
    38
    76
    S.D.
    I use a smart charger and trickle my 12 volt battery once a month.
  10. I love reading
    I have a Stanley jump starter. I used it to jump started her two hours ago. So you mean I can use it again? I am a new driver. LOL. Can you explain to me what exactly I need to do? Thank you!!!!!
  11. bisco
    52,791
    you need a smart charger fora gm battery. ctek makes a good one on amazon. let it charge overnight.
    or you can drive around for 8 hours, that's how long it would take the car to charge it.
    does that make sense?
  12. bisco
    52,791
    any idea what killed your battery?
  13. I love reading
    Got it!!!!!!!! Thank you, Bisco!!!!!!
    My battery went dead due to the long-term storage. I went out of the country for work for 2 months....
  14. bisco
    52,791
    disconnect the negative terminal for long term storage, or buy a third device, battery maintainer. maybe they have a two in one.
    I love reading likes this.
  15. egn83b
    egn83b Junior Member
    59
    Rarford nc
    That noise is normal its the throttle plate motor. You hear the pulse width modulation in the motor windings. Every prius will do this with drive by wire throttles.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Sounded to me like the inverter was screaming pretty normal has a high load on it hybrid battery charge low and 12 volt charge low. My car sounds just like that with the ac on. Inverter screaming. Any electric load makes th inverter scream ac the worst.
    And yes the throttle body whines too but mine is not loud at all.
    Take it out for long drive to charge up all battery’s but check the oil first.
