0W-40 oil, is it time?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Dec 3, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I am approaching the 140K OCI. Have been using Mobil 1 0W-20 Advance Fuel Economy oil since I've owned the car. With concerns of sudden oil consumption without notice on high mileage engines using 0W-20, was wondering if it makes sense to switch to Mobil 1 0W-40 European car formula. It's my understanding that this is the only true synthetic oil available from Mobil. Any thoughts or comments greatly appreciated. Thanks.
    About my Prius:
    - 2013 model 4 with 140K miles
    - Oil changed every 10K miles
    - The engine does not use any detectable oil
    - Major DIY service done at 120K. Cleaned all Engine components including the EGR valve and cooler. Replaced PCV and spark plugs.
    douglasjre, m.wynn, SFO and 2 others like this.
  2. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Nope, Just make sure you are using Tier 1 gas. One guy on here ran 4 tanks of gas with Techron fuel system cleaner added and he decreased his oil consumption. You see, it is carbon that causes the oil rings to stop doing their job.
    #2 alanwagen, Dec 3, 2018
    Bay Stater likes this.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    40 is too thick. If you’re concerned switch to High Mileage formulation.
    My $0.02.
  4. Mendel Leisk
    42,192
    5W20 or 5W30? Still, I'd be inclined to stick with 0W20 as long as the miraculous zero consumption continues. I'd reserve "high mileage" oil for last ditch with an engine seriously consuming oil: it's efficacy is by swelling seals, there's no reason to do that with an engine with no consumption, and once you start using that stuff it's advisable to stay with it.
  5. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I have used 0w30 mobile 1 since the car had 2000 miles now at close to 155k no oil consumption. My car is a 2013 Prius Persona .MPG has always been around 50mpg.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Just switched to 0w-40 on our 2010 with 192 k miles on the last oil change. So far, so good and I’ll stay on it;).
    I started with Castro edge and the next 2 rounds are Pennzoil Pure Platinum thanks to a great deal at Walmart on Black Friday and a $10 online rebate :).
    Some call the PP the nectar of the oil gods(y).
    m.wynn, RMB and Bay Stater like this.
  7. working1
    working1 Active Member
    121
    112
    With over 213K miles:
    - Mobil 1 Extended Performance 0W-20 and Extended Performance Oil Filter
    - Oil/filter change every 7500 miles along with tire rotation
    - No detectable oil use
    - OCC installed
    - 99% highway miles
    Lots of options to consider before changing to 0W-40.
  8. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Opinions are like noses, everyone has one. I too, have one. I would stick with what you've been using as it is the recommended weight and it has worked for you.
  9. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Unicorn tears:cool::D:ROFLMAO:...
    bisco, Bay Stater and Raytheeagle like this.
  10. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Raytheeagle, there is one even HIGHER than Platinum, called Ultra! (Specified oil of the Alfa Romeo Giulia Quadrifoglio. Must be god blood).
    Bay Stater, Raytheeagle and Simtronic like this.
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,553
    2,594
    Taylors, SC
    Don't use any oil thicker than specified. Oil cools and lubricate the timing chain and may close tolerance passages in the engine. A thicker oil slows circulation and results in heat retention in these close tolerance passages. Heat destroys seals.
    The thicker oil may slow blow by with the pistons' oil rings, but it may also cause other damage.
    Robert Holt and Bay Stater like this.
  12. ETC(SS)
    7,456
    There's two types of undetectable oil use by prevalence:
    1. Engine does not use any detectable oil because the owner isn't checking.
    2. Engine is not using enough oil to be noticeable by the owner who IS checking.
    If you're checking the dipstick quasi-regularly and the oil level stays pretty much between the dimples....Congratulations!
    You win.
    Even when your car starts drinking and smoking (all teenagers do, eventually!) it will be a while from now when you're closer to lunar mileage. I do not think that you'll notice a detectable difference by clubbing up or down between 0w20 and 0w40 in either real-world fuel efficiency OR oil burn rate.
    As mentioned above, you might benefit from a high-mileage blend, if they offer such a thing in 0w.
    If I owned this car I would use a 5k OCI but since you use designer oil and pay it done AND check your oil level more regularly than the rest of the herd I'd just keep doing what you're doing.
    You're making your own luck.....and as a result your car will probably die from that rarest of automotive maladies.......old age.
    Bay Stater and Georgina Rudkus like this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Wow. What in interesting theory.
    Alas, it is totally WRONG.
    It is WEAR that causes piston rings to let the oil pass.......usually.
    Sometimes they stick too but that's not common in an engine that is used regularly.
    #13 sam spade 2, Dec 4, 2018
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Absolutely right .......in a new engine.
    The rest of what you said is likely absolutely wrong in one with 100K miles or more though.
    I agree to not change anything unless and until you NEED TO.
    Anything that would cause a sudden and large loss of engine oil would NOT be prevented by having a higher viscosity oil in there.
  15. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Well not wrong. But a well taken care of engine should not have worn piston rings. It IS a fact that these engines DO carbon up. Tier 1 gas and good oil are very important with these engines. Read and learn.
    Excessive Oil Consumption Explained
    RMB, bisco and Bay Stater like this.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    I read.
    And I learned NOTHING that I didn't already know.
    First, this whole article is about DIESEL engines. Do you have a diesel in your Prius ??
    Second, toward the end there is an extensive list of the reasons for excessive oil consumption and carbon buildup is not anywhere on that list.
    There is one little sentence up near the beginning that mentions carbon buildup......which is much more common in diesels.......and then it is n't mentioned again in the whole article.
    YOU need to learn to pick out the important parts of what you read.
    In this case, you failed.
  17. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Maybe you failed.... Have a grownup read this to you before you start call people wrong. SMH....
    "Clogged Piston Rings: Toyota gave 2010-2015 Toyota Prii thinner piston rings and an updated piston design, both of which turned out to be not so effective. As a result, the Prii in this generation are prone to clogged piston rings, which leads to excessive oil consumption. Many Prius owners have found success by replacing the piston and piston rings"
    Toyota Prius Problems and Common Complaints | Toyota Parts Center Blog
    mjoo, bisco and Bay Stater like this.
  18. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I agree with others that there's no reason to deviate from Toyota's recommendation for the car unless you're using oil (besides the normal ~1/2 quart that gets burned between changes that most people don't even notice).
    I would not use European Formula oils. These usually have higher amounts of ZDDP, which when burnt in the engine increases the wear on your catalytic converter. If you go up in oil thickness, stick with the same ratings. On the gen 3 I believe these are GF-5, API SN.
  19. Bay Stater
    534
    771
    Central Mass
    Forgot to mention that an OCC has been installed.:oops: Strange that I can't edit my original post.o_O
  20. Bay Stater
    534
    771
    Central Mass
    Great responses PC members! (y) Thanks.
    Convinced that I will stick with 0W-20. ;) Will consider going forward doing 5K OCI's.
    m.wynn likes this.
