1.5 cents per mile instead of gasoline tax
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, May 21, 2015.
  1. Former Member 68813
    3,524
    983
    US
    FYI: Road damage rises steeply with axle weight, and is estimated "as a rule of thumb... for reasonably strong pavement surfaces" to be proportional to the fourth power of the axle weight. This means that doubling the axle weight will increase road damage (2x2x2x2)=16 times
    Gross axle weight rating - Wikipedia, the free encyclopedia
    the fuel tax at least partially accounts for that, the mile tax totally ignores it.
  2. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    OK, correct me if I am wrong 1.5 cents per mile is the same as 30 cents per gallon with a real 20 mpg vehicle (not necessarily epa). The people getting more than 20 mpg pay more under this "fair" scheme in taxes, and the extra money goes mainly to pay the taxes of those getting less than 17 mpg (those who chose guzzlers shouldn't have to pay extra taxes, that's not "fair") and the rest to pay the overhead of the program.
    On the next price spike, will that guy with the 15 mpg SUV complain that its not fair that he needs to pay more for gasoline, not just taxes than the guy in a prius or volt, or shiny new Tesla. I mean that isn't fair. Should property taxes be raised so that everybody just pays a little for gasoline, it would be more fair to those SUV and truck drivers that get hurt when oil price spikes happen, wouldn't it. Or maybe the spikes hurt more because they made a poor choice, and it would be fair to change them more in taxes so the next time they get a more efficient car. Evil capitalism fair, instead of the nice everyone pays the same. Aren't I rotten.:confused: You can cover the super efficient with higher registration fees, but still lower costs than this tax.
    Oregon Tax Is a Drag on the Open Road - Bloomberg View
    Overhead of the trial is 40%, overhead of state gas tax according to this is 0.6% and included in you cost for gas. Remove the state gas tax and I BET that cost to stations becomes a profit, not an amount returned to customers.
    #162 austingreen, Sep 11, 2015
    ftl, cyclopathic and 3PriusMike like this.
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Concervator in me is saying that if anything we need higher gasoline taxes with flat end of the year credit to encourage switch to more efficient cars.
    This is of cause if we care about national trade deficit and energy independence. Better yet dont give it back, use excess to pay off public debt.
    #163 cyclopathic, Sep 11, 2015
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Virginia would love the OReGO system, because the rural repubs are really irked that Prii pay less gaso taxes. But why green Oregon? But sounds like CA is proposing to increase $75/yr on registration so that basically hits everybody for something, and then they are adding 6 cents to pump taxes. So gaso users have quite a lot of tax to pay at the pump and also $75, and EV's just get $75. That would not fly in Virginia but CA I guess it flies.
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
    If a gas or mileage tax is meant to cover the cost of roads then it only makes sense that people that drive more miles should pay more since they are using the roads more than people that drive less. In that sense charging a flat fee per mile driven makes sense and is very fair.
  6. 3PriusMike
    3,100
    2,419
    Silicon Valley
    It would make sense if every car caused the same road damage. But heavier cars cause more damage per mile, thus should pay more. Right?
    Separately, gas cars cause more air pollution than EVs, for example. So they should pay more for the damage to the air quality, I would think.
    The existing gas tax is a good proxy for both of the above. Heavier cars get less mpg, thus pay more per mile. Bigger, heavier cars get lower mpg and emit more smog per mile as well.
    Mike
  7. bwilson4web
    16,217
    It appears to be a scheme to insert a middleman in the tax collection system. In effect, reducing net tax raised while supporting a 3-d party leach.
  8. fuzzy1
    10,455
    The weight function is of such high order that on roads built to allow commercial trucks, the weight element of common cars and SUVs is negligible. It makes sense to charge them only for their share of congestion, aging, weathering, etc.
  9. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Roads are built to handle 120,000 lb semi trucks. The difference between a 3500 lb car and 4500 lb SUV is negligible. The majority of wear caused by passenger cars and trucks in Oregon is due to the use of studded tires.
    Air pollution is a different subject than paying for road construction and maintenance.
    That works until you factor in a natural gas powered garbage truck that get the equivalent of single digit mpg but pays no fuel taxes.
    Among passenger vehicles:
    Telsa Model S: 4647 lbs
    Ford F150 4x4 Supercrew: 4696 lbs
  10. cyclopathic
    3,292
    547
    2014 Prius c
    So under OreGO they will pay as much as 1970lbs Mitsubishi Mirage and 1680lbs Smart? very appealing, indeed!
  11. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    This is probably going to be a state-by-state thing, unless the Feds step in.
    California is going to want to shift the tax burden to gasoline/diesel users as an incentive for alternate fuels cars.
    Virginia/Idaho etc probably want to go the opposite direction, and make sure alternate fuels cars including hybrids pay the same gaso tax as a FORD F350.
    One would think Oregon/Washington would fall in line with CA policy.
  12. bwilson4web
    16,217
    When the net loss of tax revenue from the overhead becomes evident, it will join the dust-bin of 'speed cameras' and other attempts to steal taxes by a private corporation.
    el Crucero likes this.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    BUT.. there is no government bureaucracy!
  14. bwilson4web
    16,217
    Just thieving government contractors.
  15. cyclopathic
    3,292
    547
    2014 Prius c
    BUT.. we all know gov'ment is bad and private business is good, right?
  16. fuzzy1
    10,455
    Only half of us know that. The other half of us know the opposite.
    FL_Prius_Driver likes this.
  17. cyclopathic
    3,292
    547
    2014 Prius c
    Actually no. Statistically for every rep there's 1.2 dem but this belongs to FHoP forum.
    Agree with wtracy states need federal guidelines otherwise this will end up haywire. Problem is what are the chances of that happening in election year?
  18. JSH
    JSH Senior Member
    2,605
    140
    PDX
    California and Washington are also thinking about switching to a fee per mile to replace the gasoline tax. California has authorized a trial similar to Oregon's: California Road Charge Pilot Program - Technical Advisory Committee (TAC)
  19. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    It also "makes sense" that people that use more fuel are driving a bigger (and using more limited resources) vehicle or driving farther with the vehicles they have. That makes perfect sense from a road support need. Even more interesting is the "Trip to Disney World" question. It seem more fair that the states roads being used should be the states getting the funding. This is naturally solved with energy taxes instead of states collecting out of state mileage for their coffers (and leaches). What am I missing in this concept?
    3PriusMike likes this.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    The actual price of gas was estimated at $15/gal. It is only fair that gas guzzler owners are subsidized more.
