For Sale 1.8L HYBRID ENGINE 2ZR-FXE REBUILT MOTOR
Discussion in 'Private Sales' started by RightOnTime, Jul 23, 2025.
  1. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Hot Links - Engines, Heads & Blocks - Engines - Engine Rebuilds - HybridPit Rebuilds
    Gen 4 (2016-2022) Conversion Package to Gen 3
    This Engine rebuild is designed to provide a comprehensive restoration of the engine, focusing on essential components and services to ensure durability and performance. This rebuild includes a wide range of new parts and professional services to address key areas of the engine.
    Parts Included:
    • Toyota OEM (2021) Piston Rings
    • Camshaft Bearing Cap Oil Hole: Ensures proper lubrication of the camshaft bearings.
    • Headgasket Fel-Pro: Seals the engine block and cylinder head to prevent leaks and maintain compression.
    • Valve Cover Gasket: Prevents oil leaks from the valve cover.
    • Engine Crankshaft Seal: Seals the crankshaft to prevent oil leaks.
    • Various Gaskets and Rings: Includes gaskets for the camshaft bearing cap, oil strainer, and oil filter bracket, ensuring all seals are secure.
    • PCV Valve - Toyota: Controls the release of gases from the crankcase, maintaining engine efficiency.
    • Rear Main Seal Fel-Pro: Seals the rear end of the crankshaft to prevent oil leaks.
    • Headbolt Kit Fel-Pro: Provides high-quality bolts for securing the cylinder head.
    • HI-TEMP Silicone Liquid Gasket: Used for sealing high-temperature areas to prevent leaks.
    • Engine Block Piston Service: Comprehensive service for the engine block and pistons, ensuring they are in top condition.
    • Gen 3 Cylinder Head Service: Service for the cylinder head to ensure it is clean and functioning properly.
    Labor and Services:
    • Long Block / Head Assembly: Professional assembly of the long block and cylinder head, ensuring all components are correctly installed and functioning.
    This rebuild package is tailored to provide a reliable and efficient engine, combining high-quality parts and professional services to enhance the vehicle's performance and longevity. The 4th Gen Toyota Prius rebuild focuses on essential components and services, making it a solid choice for those seeking a thorough and dependable engine restoration.
    $3116.00
    HybridPit Installation Service Available
    7314 Melrose Street
    Buena Park, California 90621
    (855) 492-4440
    Burna J likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,135
    6,985
    Texas Hill Country
    A little confusing
    This sounds like you replace a gen4 engine with a gen3
    Using a gen3 head
    Here it sounds like a "4th Gen Toyota Prius rebuild"
    Air_Boss likes this.
  3. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Just a break down of the engine starting from the bottom:
    Bottom End - Gen 4
    Felpro Headgasket
    Gen 3 Head
    Gen 4 Cam Assembly
    Gen 4 Valve cover
    Gen 4 (2016-2022) Engine Conversion Package for Gen 3 Prius Vehicle.
    This is a plug and play install without any modification to the EGR system using the GEN 3 Head.
    Xterra72 and MrPete like this.
  4. rjparker
    11,135
    6,985
    Texas Hill Country
    Interesting
    Gen3 or 4 water pump needed?
    RightOnTime likes this.
  5. Boots_de_cat
    Boots_de_cat Junior Member
    Kearney, NE
    We just talked to your guy today about ordering this on Monday. I'm really looking forward to putting this engine in my 2012 Prius! My headgasket just went out for the first time at 330k miles. My husband bought this exact type of engine from you last year, for his 2010 Prius. He already put 40k miles on it and it's going strong. I hate to replace my entire engine (I was hoping I'd get to 500k on it), but at least I'm getting something that's way better than a wildcard JDM engine.
    By the way, your customer service guy is top notch! We chatted about other issues to look for in the future, since I still have the original master cylinder and hybrid battery (actually had the original 12V, too, up until last year, LOL). He gave me a LOT of really good info and I really appreciate that. You guys get 5 stars from us!
  6. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    Need a NY/NJ Hybrid Pit…
    Burna J and RightOnTime like this.
  7. Mendel Leisk
    42,373
    Why paint the blocks black?
    douglasjre and RightOnTime like this.
  8. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    I have this engine installed on
    June 20, 2024 at 235,915 miles.
    It's at 252,950 miles now.
    It's a bit over a year and it's running well. Thanks @RightOnTime and thanks to Greg and the crew for getting my car back on the road.
    looking forward to making my way south for my major maintenance services soon!
    #8 Xterra72, Jul 27, 2025
  9. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Secret is out! We are very confident for us to release this setup to the public because without your help and feedback this would still be on the testing phase
    Xterra72 likes this.
  10. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    SOLD SOLD SOLD
  11. rjparker
    11,135
    6,985
    Texas Hill Country
    Is the inverter cover from a gen4 or aftermarket? It seems there are several modifications under the hood.
  12. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Inverter cover is from a Lexus CT200h known as the ‘Fancy Prius’
  13. richard203
    richard203 Member
    284
    61
    SF
    was wondering do this even pass visual smog?
  14. Xterra72
    1,437
    1,684
    I had my first smog done on this new engine. Passed with no problems. Got my registration and stickers. Good for another 2 years!
    Viviparous, RightOnTime and Brian1954 like this.
