1.8L starting rattle, knock, events
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Nov 14, 2010.
  1. Never or not happened, yet. (miles? months owned?)
    55.6%
  2. 1 time (miles? months owned?)
    27.1%
  3. 2-3 times
    10.4%
  4. 4-7 times
    2.8%
  5. 8 or more times
    2.1%
  6. Reproducible (details?)
    1.4%
  7. Spring
    2.1%
  8. Summer
    2.8%
  9. Fall
    9.0%
  10. Winter
    12.5%
Multiple votes are allowed.
  1. evchau
    evchau Junior Member
    Alhambra
    my Rattle - knock events started last week after the car sit for about 8.5 hrs. It about 4:30 - 5:00 am, Temp 70 degree f. and repeated until today, the rattle - knock event started and then goes away, then I saw check engine light on, I went to the Dealer, got charge $48.08 and nothing done yet,
    trouble code P0138, P0607, P0300, P0302, P0303, P0304 told me I need to change out the part # 89465 47080 cost $200.00,
    anyone had this issue fix yet????
  2. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Almost all have it after the previous run had an incomplete warm up cycle. Was that your experience, too? The part you ref is an oxygen sensor.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You are the first that I have read about that had a Check Engine Light and DTC codes. How many miles do you have on your car? If less than 36k miles it should be covered under warranty.
    The codes indicate the Heated O2 sensor that Skoorbmax indicates and then Random Misfire.
    P0138 - O2 Sensor (Bank 1 Sensor 2)
    P0607 - Control Module Performance
    P0300 - Random Misfire
    P0302, 0303, 0304 - Cylinder 2, 3 and 4 misfire
  4. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Interesting, could be a clue. The O2 sensor was the first (and only) engine component that failed in my belated Acura Integra.
  5. evchau
    Alhambra
    After reading this post, I print out a few key post from here, took a Video of the event, took the car back to the same dealer, so far, they ask me to email them the Video so they can send it to Toyota. I had a schedule this coming Tuesday to turn my car in, they want to see if they can see the event the next mooring. They will have a field engineer from Toyota to come check out my car. Also change out the VVT-i and o2 sensor.
  6. deros68
    deros68 bought ours in 2002
    Washington state
    2002 Prius
    We have a 2002 with 112,000 miles - runs well but we have ALWAYS had the following: At start up the fuel pump cycles 1, 2 sometimes 3 times. If we try to start it before the 2 or 3 cycle it starts with SHAKE / KNOCKS - then runs fine. If it is not started for a week - then even if we let the fuel pump cycle 3 times - it starts roughly - even longer. We have been taking it to Toyota dealers in Calif & Washington State - no problem found they say. I had the gas tested 4 times - no problems there. This happens only on COLD starts and letting it sit for a week ? The O2 sensor checked out fine - the latest dealer says fuel pump is OK. damn it - it's been a great car otherwise . Any ideas ?
  7. Mshap
    Mshap New Member
    Buffalo grove IL
    Bought our 2011 about a month and a half ago. We put 3200 miles on it (trip to Florida) and this morning went to start the car to go for breakfast. Had a very noticeable knocking from the engine for just about 3 seconds then went away. Wife told me it did this once before and it's always after the car sits for about 2 or 3 days.
  8. Skoorbmax
    2,641
    265
    Western NY
    So it obviously hasn't been resolved, which leads me to think Toyota still doesn't know what this is.
  9. Mshap
    Mshap New Member
    Buffalo grove IL
    Nope, we brought it in and had it checked. They said they couldn't verify it. Just have it on record now if they do figure out a fix that we had complained about it.
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    It happened 2x to me. On the second occurence, once I put the car in gear, it stopped immediately. Now when I'm ready to go on a cold start-up, I never wait for the engine to start before I move the shift lever into gear and it hasn't occurred since. On initial start-up if cold, the car moves on battery giving the ICE a few seconds to warm up before engaging it for drive.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    That's how I always did it. Power up, toss in gear. Another one of the nice things about Prius over a conventional.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Has this ever occured when the car is moving with cold start? Or warm start?
    Like said above, pretty sure I always had that sucker in gear and moving before ICE kicked on. I'd usually have backed out of garage, in driveway, then ICE comes on.
    Still, don't want to be rushed to put it in gear.
    When I'm starting the Accord, waiting some seconds, I recall I'd be halfway down the street in the Prius. :eek:
  13. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    It happens to my gen 3 on a very cold start (below 0 F ). By moving the shift lever to nuetral, the generator is disabled and does not load the cold engine. After the engine smooths out, I shift back to D then park so the generator reconnects and warms the traction battery a bit before driving.
  14. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Had it happen again and I KNEW it would happen, even had my father in law stand there so he could hear it.
    This "event" is totally repeatable*, any dealership claiming they can't recreate it isn't paying attention or purposely avoiding it.
    *Make sure engine is cold, preferably in cool weather. Start and move car about 10 feet, ICE must come on at start-up and still be on when you turn car off. Let car sit over night. Start car next morning {{{insert bucket of bolts sound here}}}
    This is EXACTLY the situation for my 3 events. 1st time was a surprise, 2nd time was an error on my part, 3rd time was almost on purpose to test my theory.
  15. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Well Sporin, your repeatable steps mirror what others have suggested, however, I don't think anyone has been able to recreate it at will. I have never had it happen once myself in 35,000+ miles. I did try essentially the steps you outlined to make it happen but it did not.
  16. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Take it to the dealer if you can repeat it and show it to a tech or service manager.
    Let us know the outcome.
  17. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    If I ever find I can be without my car for 3 days then I just might. In the meantime, I'll be making sure I don't set my self up to repeat it at home.
  18. Skoorbmax
    2,641
    265
    Western NY
    This is how I tried to reproduce it and couldn't, though I may have waited only several hours. I do think that this is the best shot a person has at causing this event, though. It really does have to do with the engine shutting down while cold and not getting warm.
    Problem is he'd have to:
    1) Drive it there
    2) Come back next day when it's cold and turn it on
    3) Come back the next day!
    And then even still they'll be like "Yep, I do hear it!" and that's that, because really it's not actionable. What can they do?
    We're at 30k now and have had this happen twice, I don't think it's happened in many, many months since.
  19. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I agree that it might be an inconvenience but Sporin is the first person that I have seen on here that is able to reproduce it at will. Are we going to try to get it to a dealer and have it documented or are we going to just whine and bitch about it on PC?
  20. Skoorbmax
    2,641
    265
    Western NY
    Whine and bitch. What do you think the dealer is going to do? Some have "registered" this occurrence with their dealer, but nothing more.
