1.8L starting rattle, knock, events
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Nov 14, 2010.
  1. Never or not happened, yet. (miles? months owned?)
    55.6%
  2. 1 time (miles? months owned?)
    27.1%
  3. 2-3 times
    10.4%
  4. 4-7 times
    2.8%
  5. 8 or more times
    2.1%
  6. Reproducible (details?)
    1.4%
  7. Spring
    2.1%
  8. Summer
    2.8%
  9. Fall
    9.0%
  10. Winter
    12.5%
Multiple votes are allowed.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Nice to see those videos guys, but I must say, your rattling was pretty tame compared to the two I had (long ago). Mine felt and sounded like someone taking a heavy sledgehammer to the engine. The first time it happened scared the crap out of me.
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I haven't seen this mentioned yet but if this is a problem with the ICE ingesting condensation that forms on the intake manifold, isn't the dewpoint a big factor in this? This would add to the rareness of this, the seeming unpredictability, and the varying levels of knocking experienced.
  3. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    ^That is a valuable data point, DetPrius, and one that I will start paying closer attention to as I try to repeat the occurrences.
    Spiderman, the first time it happened to me, that was the impression I had, too. This was after leaving it sitting for days in temps that dropped to the single digits. It may very well be that with more time in the environment, there are increased levels of moisture being "coughed" out due to condensation.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes it may be related to moisture. As I recall the times I have experienced it temperatures were around 30 to 40 degrees with fairly high humidity, usually not below 20 degrees. When it gets cold here it is usually dry and I had no problems then. If I had to "prove" I had a problem by leaving it at a dealer until they encountered it I would have to leave my car there all year.
    In my case it's not that it happens frequently, it's the violence of the shaking that worries me.
    Since this is an emission control related problem has anyone reported Toyota's failure to "act until proven policy" to the EPA?
  5. WE0H
    WE0H Senior Member
    3,247
    528
    Maybe this is of some use?
    http://www.epa.gov/oms/consumer/warr95fs.txt
    I have had cars in the past where a dealer said no to a warranty claim to later say bring it in after they were told it was a emission control device that was causing the fault.
    Mike
  6. vinnie97
    1,430
    277
    Somewhere out there
    Being in a desert area now, this is especially true for me. Even so, I've managed to recreate the problem 3 times now (yesterday's heavy moisture helped, I suspect). IF the dealership followed the instructions, they could probably recreate the problem within a week, if not less. No other way to make sure they follow the procedure unless you remain on the premises yourself, which I may end up doing for a day, since I apparently have nothing else better to do.
  7. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    "Hammering" is the sound I would describe as well. I am of the opinion that it is much more than an intake manifold issue. I live in a very mild and stable climate. There would have to be quite a volume of water in the intake system/cylinders/manifold to cause this. When my car has done it, it sounds as if the engine is self-destructing; as if many heavy reciprocating parts are out of sync.
    Engine tear-downs of cars that have experienced the type of "hammering" that many here have dealt with would be most interesting.
    This is starting to sound like Porsche's M96 engine problems. Porsche were silent about them, until engines started to "grenade" and lawsuits were filed. Porsche eventually offered "out of warranty" engine replacements, but not without lots of resistance, and plenty of bad p.r. from owners and enthusiasts.
  8. Trev
    Trev New Member
    Taree NSW Australia
    We had this problem ie. rough, misfiring engine (intermittent) at startup that ended up being a injector problem. Try a fuel additive .
    Our Prius sounded exactly like all the videos I have seen on this forum about this problem.
    Trev
  9. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    I dropped off my 2011 Prius Five at the dealership this evening. I showed them both of my videos and they said they still had to reproduce it for themselves. I explained how I had done it and they looked clueless. :confused:
  10. vinnie97
    1,430
    277
    Somewhere out there
    They're fronting with the clueless act. They of all people should know how to follow procedure, lol.
    I hope you heard some good news today.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I don't believe the highlighted is quite true.
    The common misnomer is 'the A/C shuts off when the car is stopped'. From my test drive in the 2011 Insight, it was shown that ... when in Eco mode, the A/C goes to a lower fan setting, but doesn't shut off.
    I don't know what it does out of Eco mode.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    More like .. 5 seconds. if they deny, ....
    The car should not knock for 1 second on startup.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    This is getting crazy ... people thinking of trading in their car to get another that hopefully doesn't knock on startup.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Being that it is an intermittent, I would think a video should suffice. Dealer may never get the conditions to reproduce the problem.
    Last thing an owner needs is 'sorry, we couldn't reproduce so here's your car back'. Then you get into a back and forth, wasting your time.
  15. El Dobro
    El Dobro A Member
    7,104
    3,282
    Sounds like the Toyota dealers are taking tips from VW dealers.
  16. vinnie97
    1,430
    277
    Somewhere out there
    Video may still not be enough, especially if the dealership insists on repeating it.
    I wasn't necessarily connecting a 28-second series of knocks as being the catalyst to go to claims court but good grief, they should be able to put two and two together with something so glaringly obvious (coupled with the fact that Toyota has issued a TSB for the very problem). I have only been able to repeat it with a 3-second knock...not good enough for my local dealership who demands that it recurs in the presence of their own techs.
  17. Unlimited_MPG
    218
    24
    Federal Way, WA
    No word today from the dealership. I'm hoping they are giving it a good cold soak. When I dropped it off they pulled me into the Service Managers office and called in their lead tech to watch the videos and ask some questions. So I'm hoping he's taking his time with it or better yet maybe just fixing the problem per the TSB?? :cool:
    Either way they gave me a loaner car so I have transportation.
  18. vinnie97
    1,430
    277
    Somewhere out there
    Gave you, eh? I had to pay for my loaner, and all I ended up getting out of it was a lousy free oil change (my last complementary service as I approach the 2-year mark of ownership). Good luck!
    If anybody in the Las Vegas area has had luck with getting this done without a hassle, please PM me details or post them here. Thanks. It's a 2-hour trek but I'd do it if I could find a service center that would meet me halfway (figuratively speaking of course).
  19. WE0H
    WE0H Senior Member
    3,247
    528
    There should be a list made up of dealers to stay away from because of failing to perform TSB's or other known repair issues. I say boycott those dealers and go find another that will take care of a customer.
    Mike
  20. vinnie97
    1,430
    277
    Somewhere out there
    And alternatively a list of dealers who do right by their customers.
