1 million Prius' to be recalled. Fire hazard.
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Sep 5, 2018.
  1. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    ArcPrime likes this.
  2. fneil
    fneil Member
    71
    52
    Carrboro, NC
    This article is worded pretty vaguely - I don't think it clearly says N.A. Primes are not included in the recall. In fact, since our Primes were built in Japan, I would expect the recall to apply to them. Why would the engine wiring harness be different for Primes sold in N.A. vs. Japan?
    jaqueh and ArcPrime like this.
  3. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    The issue affects vehicles produced in Japan between June 2015 and May 2018, and includes the plug-in version of the Prius and the C-HR compact crossover SUV sold in Japan, Europe, Australia and other countries
    Sounds like Prime is affected too.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
  5. ArcPrime
    201
    166
    Arcadia, California
    Salamander_King likes this.
  6. Mark57
    2,945
    2,740
    OK
    Mine didn't either.
  7. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    same here.
  8. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Mine is affected. I'm wondering how some are affected but not others. There are 2 different assembly lines, correct? I would have thought both use the same design.
  9. Salamander_King
    11,024
    8,978
    New England
    Yours is Prius Four and not PRIME isn't it? Toyota notice specifically calls for PRIUS. Maybe US PRIME were on different assembly line? Just my guess.
    davecook89t likes this.
  10. bisco
    52,830
    if mine is affected, i'll just pile it up on top of all the others.
  11. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    Yup. Mine is included in the recall.
  12. Trollbait
    12,822
    They've likely pinned done what has lead to the fault, and determined that NA Primes weren't affected. The recall could expand later though.
    Plenty of human labor on the lines. Some gen2 Prii could have had a cover plate on the inverter case installed upside done, and that could lead to cutting wiring.
  13. bwilson4web
    16,530
    Hummmm, my Prime would be a significant part of a Model 3 ...
  14. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
    If affected, won't you get a notice in the mail at some point? And that could be a problem if charging in a garage attached to your house.
    Mine checked out OK with vin #.
    #14 huskers, Sep 5, 2018
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Left- and right-hand traffic - Wikipedia
    Areas in red are Right Hand Traffic, areas in blue LHT. this will effect the steering gear in the engine compartment.
    #15 JimboPalmer, Sep 5, 2018
    fneil likes this.
  16. fneil
    fneil Member
    71
    52
    Carrboro, NC
  17. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    In addition to being configured with the driver's controls on the right for Japan (where they drive on the left side of the road), I believe that the Japanese version of the Prime is equipped with a CHAdeMO charging port in addition to the J1772 on the US model.
    I don't know if this has anything to do with the wiring harness problem. But because the problem was described as having to do with wear and chafing of the harness, I would suspect that no one is in immanent danger of bursting into flames if they have not put on a lot of miles on rough roads. This sounds like a preemptive recall rather than a response to an immediate problem.
    Nonetheless, as soon as I hear from Toyota, I'll be bringing my Prime in for whatever modification is deemed necessary.
  18. Trollbait
    12,822
    But the recall does effect Prius in North America, and Primes/PHVs and other hybrids in markets that could have left hand roads.
    The article mentioned there was one incidence of a car smoking from the short.
  19. Old Bear
    712
    1,050
    The news reports are a little confusing. The Wall Street Journal just appended an errata to its story from earlier today:
    Corrections & Amplifications
    Toyota is recalling about 192,000 Prius vehicles in the U.S. An earlier version of this article
    incorrectly stated the U.S. recall included the Prius Prime plug-in hybrid. (Sept. 5)
  20. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    They might have multiple suppliers of the wiring harnesses. The parts from one supplier might be faulty, no problem from another supplier.
