1 year old - Got "low 12v battery" warning
Discussion in 'Gen 4 Prius Main Forum' started by Zojja, Feb 6, 2017.
  1. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    I've seen a few posts about the battery but nothing about this specifically. This morning, I went out to the car, tried to turn it on, got a "12v low battery" and also a message about putting the parking brake on. So I put the parking brake on, the car dash eventually went crazy, I pushed the start/stop button and then pressed it again to start the engine and everything was fine.
    Is this something I should worry about?
    ETP likes this.
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Check your battery voltage..after couple hours seating ....without powering on car and do a load test..that will give you health of 12v pack....things you are experiencing are related to weak 12v battery
    RCO likes this.
  3. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I would say yes. Take to the dealer to check codes, or check them yourself if you can. 12v battery is the weak link in the system IMHO.
    RCO likes this.
  4. Surferboy
    Surferboy Junior Member
    Los Angeles
    Definitely take it into get the battery checked. My 1 year old 2016 Prius did the same thing a couple times and ended up having to get jumped. Took it into the dealer and the 12 V battery was dying and they replaced it for free. All fine now.
  5. Mendel Leisk
    42,254
    It's interesting that car FINALLY has a specific message about low battery.
    The question in your last sentence: of course, why ask, lol. For starters, check the voltage with the car off, with a digital volt meter.
    Have you:
    1. Left any lights on, doors ajar, etcetera, in past?
    2. Been using the car infrequently, left it sitting for days at a time, doing only short trips?
    3. Frequently sit listening to the radio in accessory mode?
    RCO likes this.
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    What Mendel asked! ^
  7. Hoddie
    Hoddie Member
    87
    110
    Belgium
    This just happened to me except attempting to re-start the engine resulted in the same 'dashboard going crazy' thing. I let it sit for 10 mins before trying a third time, and it turned on fine. It has since started fine every time.
    I had been listening to music in Accessory mode, while waiting to load onto a car ferry. About 30 mins in I received a phone call and the car relayed it via Bluetooth. Immediately on hanging up the phone, the 12V battery warning flashed up on the dash and all other dash lights flickered, accompanied by several beeps and other warning messages I didn't get chance to read.
    I'm very surprised by this, it's not as though I'm a big user of Accessory mode, and my last Prius didn't need a battery change until year 9.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    How many bars showing on the hybrid battery when you tried to start up compared with number showing when you had earlier switched off?
  9. Prodigyplace
    12,710
    11,848
    Central Virginia
    How would this affect the 12 volt auxiliary battery? When the car i switched off, the HV relay is open so the hybrid traction battery is not connected to the car, for safety reasons.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's the HV battery that cranks the engine
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    That would not trigger a "12v low battery" warning, though.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You're right, I'll stop digging now. :LOL:
    kithmo, bisco and Prodigyplace like this.
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    This reads like a cautionary tale for people who like to listen to their radios while parked. Do so in READY mode. You can sit there for days and not run down the 12V battery. The HV battery will keep it charged and the engine will start whenever the HV battery needs a shot in the arm. People camp overnight in these cars with the air conditioner running. I don't even know why it needs an ACC mode.
    jtg61, rbdigital, kenoarto and 3 others like this.
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    Probably some obscure US law much like the need for Neutral and the inside reverse beeping.
    jerrymildred likes this.
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I didn't notice a 12volt warning, but 8 mths ago, I had "and all other dash lights flickered, accompanied by several beeps and other warning messages I didn't get chance to read.", though I did see the word MALFUNCTION several times. I was driving at the time, I stopped, POWERED OFF, back on, it started normally, went for 5 months till I took it in for service and asked them to check it - it threw up an error with the BRAKE LIGHT SWITCH. Which is being replaced tomorrow after being sourced from Japan.
    RCO likes this.
  16. bisco
    52,770
    i'm surprised that the new, larger battery under the hood would drain that quickly. i'd love to know the specs, compared to the old one. this is a disappointment, as toyota made a big deal of how they solved one of the biggest complaints of previous generations.
    i'd also like to know if there is a standard size replacement for under $100.
    RCO likes this.
  17. Hoddie
    Hoddie Member
    87
    110
    Belgium
    I presume the Accessory mode is so you can still use the radio, navigation planner, lights, etc. while in an enclosed space. Using Ready can trigger the petrol engine which wouldn't be ideal. I forgot to mention, when the low battery warning first appeared, after turning the car off, when attempting to start the engine with the combination of brake and the power switch, the brake was very difficult to press, almost as though there was a mechanical obstruction.
    I'm booked in at the local dealer on 19/5 for an accessory fitting, and will ask them to take a look at that time.
    I have Carista somewhere, maybe I could use that to get at the error codes.
    I should add, here in Belgium you're not supposed to leave the engine running while idling, even at traffic lights. Of course most people do, but you sometimes get stuck behind someone who did turn theirs off, only to struggle to get it going again when the lights turn green... :D
  18. bisco
    52,770
    what does the o/m say about accessory mode? i think the 12v being dead affects the brake.
  19. Samprocat
    491
    297
    Lincoln, NE
    Voltage is not a proper way to diagnose battery health
    It need load test..to see how well it run under load....and also this will give you SOC
    RCO and kithmo like this.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    The manual says this:
    jtg61, Hoddie, RCO and 1 other person like this.
