1 year old - Got "low 12v battery" warning
Discussion in 'Gen 4 Prius Main Forum' started by Zojja, Feb 6, 2017.
  1. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Gen 4 12v is: 45Ah 295 CCA. IIRC the Gen 3 was 35 or 38Ah ?
    RCO and bisco like this.
    52,912
    is that a significant improvement? what about the chemistry?
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    The label has lead and explosive gas warnings so I would assume it is lead acid.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Waiting to load onto a car ferry is usually not in an enclosed space (actually never in my experience, but I won't rule it out).
    I wouldn't suggest keeping it in ready for long in an enclosed space, but the engine would only run for a couple minutes to charge up the battery a little. Probably harmless unless it's sealed up very tightly and runs several times. Still, not recommended. Bottom line, if you're in the garage, and you need to have power to the car for some reason, either set a timer (as in don't just sit and listen to the radio) if you want it in ACC mode, or open the door and put it in READY mode. I often just reach in and hit the power button twice to look at the odometer or something. But if I'm waiting for someone and want the radio, I keep it in READY. That's what the owner's manual says, also. That's true for any car. Thankfully, we have an option that non-hybrids lack.
    RCO likes this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I haven't seen any Toyota documentation saying the 12V battery is "vastly improved". It's still a 12V lead acid battery, of rather small size. It can still be drained if you try hard enough. ANY modern car has this problem! Just ask a Ford owner! In fact, the Prius will run just fine with a compromised 12V battery once in "ready", but a Ford won't. The automatic transmission won't work (a friend's experience). ;)
    The "improvement" in the G4 is that you can use a battery from more suppliers and it's a bit easier to get at. Oh, and it should be less expensive, I guess. THAT remains to be seen.
    The answer to the problem is in the owners manual, as has already been posted above. Leave the car in "ready" when you are listening to music etc.
  6. bisco
    52,912
    it's in the walk around video review danny did with the toyota prius expert, early on, when he went to japan i think.
    but since you haven't seen it, it must not exist.
    RCO likes this.
  7. David Beale
    5,963
    1,990
    Edmonton Alberta
    That is not a Toyota documentation. It's a "Danny doc." ;)
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    I believe the Toyota Prius expert is a Toyota employee.
  9. djSyndrome
    djSyndrome Member
    30
    27
    Seattle-ish
    Just so I'm reading this correctly: you're advocating leaving it in Ready - which can fire up the ICE at any time - in an enclosed space, as long as it's "not for very long".
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    The best recommendation is not to do this in an enclosed space. The alternative, is READY mode.
    The manual already states you should not be using accessory mode for this. Since they warned of issues using Accessory mode, I would not expect any warranty assistance if their advice is ignored.
    RCO likes this.
  11. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
  12. jerrymildred
    11,517
    14,171
    Tampa, FL
    That would not be "leaving it in READY."
    But, if a few seconds would hurt you, then you wouldn't be able to safely walk past the tail pipe with it running. Mechanics start dirtier engines than this one in their garages for a few moments and have done so for ages. You'll soon know when it's time to shut it off. You fire it up, say "Whoo hoo, it works," and shut if off. Not recommended, but often done.
    RCO and Mendel Leisk like this.
  13. bisco
    52,912
    how does 'open the door' not tell you it is no longer a closed space?
    RCO, Prodigyplace and jerrymildred like this.
  14. Hoddie
    Hoddie Member
    87
    110
    Belgium
    I didn't say it was, I was just responding to your query about why the Accessory mode even exists. There are occasions when you need power when in an enclosed space. Just one example, I don't think my neighbours would appreciate me having the ICE on in our communal underground parking complex while I'm cleaning inside the car, or updating my nav destinations or whatever.
    I think that considering the mode does exist, it's not unreasonable to think you won't encounter issues by using it on occasion. In my case, probably just the third such occasion.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    On occasion. I was exaggerating a bit and it's unfortunate that that has become central when it was mostly just a wise crack. ACC can be useful once in a while. ;) But it's not for listening to the radio. I sometimes use ACC for opening my windows. But you make it sound like your engine will run the whole time it's in READY. It only runs a little now and then (assuming it's warmed up), and many people in this country idle their cars far longer in communal (or private garages with the door open) in the winter. I don't advocate it. It's not good for the car, the environment, or the wallet, but they do it. It would seem that Belgian drivers are more enlightened, and that's good news. :)
    RCO and kithmo like this.
  16. Tideland Prius
    16,683
    How long are your traffic lights?? :confused:. All do all Belgium-spec cars come with auto start-stop?
    It's interesting that it's now a 20 minute timer. The Gen 2/3 with the smaller 12V has a 1 hour timer.
  17. Mendel Leisk
    42,381
    ive seen an instruction to top up battery electrolyte, on 4th gen Prius. Thought it was in owner's manual PDF, but of course now I can't find it. Bottom line, it's very conventional, and maintainable.
    RCO, Hoddie and kithmo like this.
  18. Hoddie
    Hoddie Member
    87
    110
    Belgium
    Some of the side roads to the main feeders for the inner ring in Brussels can be on red for 3-4 minutes. Doesn't sound so bad but when you're sat there it can seem like an incredibly long time, probably made worse because you can see the countdown for the pedestrian crossing which changes at the same time.
    Not sure about your second question. I've seen police ask bus drivers to turn their engines off when letting passengers on and off which seems crazy given the black plumes of smoke that billow out when they're turned back on.
    RCO likes this.
  19. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    That would also turn the Air-Conditioning off - could get dangerously hot - or wear out the window winders each time.
  20. Prodigyplace
    12,720
    11,852
    Central Virginia
    Except in a Prius. The air conditioning is not dependent on the engine. I started home last night in EV mode with air conditioning running.
    RCO and alanclarkeau like this.
