1 year old - Got "low 12v battery" warning
Discussion in 'Gen 4 Prius Main Forum' started by Zojja, Feb 6, 2017.
  1. Mendel Leisk
    42,347
    Did a little more digging: the US and Canadian Owner's Manuals don't describe electrolyte top up, but the Australian version does:
    https://toyotamanuals.com.au/document/landing_page/prius-50-series-owners-manual-nov-15-current
    RCO and Prodigyplace like this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Can't see any of those little black dashes in my battery plug holes :rolleyes:
    RCO and bisco like this.
  3. Mendel Leisk
    42,347
    The Australian manual vs North American has some other notable differences, just reading quickly:
    1. Tire rotation is "conventional": straight back, and cross-to-front. (page 391)
    2. A much fuller gamut of oil weights is recommended. (page 500)
    It's roughly 250 pages briefer, and yet seems more succinct.
  4. Prodigyplace
    12,713
    11,848
    Central Virginia
    Do you have the clear fluid level on the side? I did not notice that on mine.
    Here is the top of mine.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The heat in Australia evaporates the water more than in places like Texas? I can't see the level on the outside of most battery cases, but I can see the meniscus form when the electrolyte touches the two arcs of plastic when I remove the caps (FJ Cruiser Panasonic original battery - 2007). Maybe I'm just blind! ;)
    Oh, and I've seen several batteries (different vehicles I've owned over the years) act like they're about to fail, only to recover -fully- once distilled water is added to the proper level. Funny how the end cells seem to loose the water more than the center ones, even though there is no corrosion on the terminals. I wonder if it's greater hydrolysis from the extra metal in those cells (for the terminals)?
    Are those terminals JIS or SAE? They look like they're still JIS.
  6. Mendel Leisk
    42,347
    SAE equals bigger posts, North American Standard? I think that's what they are, just eyeballing.
    I wonder are the case side walls black/opague or translucent. In the past I've found it best to remove the battery, have good backlight, and rock the case a little too, to see the level move.
    #46 Mendel Leisk, Apr 11, 2017
    jerrymildred likes this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Case is white, I can see the level lines on the case but can't see the electrolyte, it's too clean or the case is not translucent enough.
  8. Prodigyplace
    12,713
    11,848
    Central Virginia
    The sides on the US battery are white/translucent. I did not notice the electrolyte level, bit the side of the battery was in the shade.
  9. Mendel Leisk
    42,347
    I've found you have to take it out, put a light behind it (the sun or whatever), and rock it a bit. Something to do at battery mid-life, together with cleaning the posts and clamps.
  10. Tideland Prius
    16,680
    Wow they are long. I think lights here are typically 1 min long. Maybe 1.5 mins if the junction is a feeder route. (A cross junction with 3 directions feeding one)
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My UK dealer confirms...
    1. No tyre rotation necessary
    2. First service at one year
    So much for standardisation. (n)
    kithmo and bisco like this.
  12. Mendel Leisk
    42,347
    Tire rotation is debatable: if you rotate tires 8x5,000 miles, vs 4x10,000 miles is there going to be that much difference? I suppose the difference is the incidentals done at the same time, visual inspection of the brakes, check for undercarriage damage and so on.
  13. David Beale
    5,963
    1,990
    Edmonton Alberta
    Hey, the nice thing about standards is there are so many to choose from!
    I didn't rotate the original tyres on Pearl S until I replaced them. They were worn evenly, all four. I only replaced them at 65,000 km because I felt I needed -real- tires, not "rim protectors". I put on Nokian WR3, so I would feel a little safer in winter. The guys at the tire shop wondered why I didn't want the originals back. To quote them, "they are still good". Yeah, right. If you don't mind the "low bidder" crap that slides if the road is even thinking of freezing. We get below freezing temps. here for 7 months of the year. Not all day, but Murphy will tell you, whenever you need to drive. ;)
    RCO likes this.
  14. Tideland Prius
    16,680
    You got good mileage out of the Ecopias. Mine probably got 1/3rd less (I had two sets of tires so hard to guess exactly but it was 87,500km when I got ride of both sets). Mine were slipping when I was driving up Kicking Horse Canyon in the rain.
    RCO likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Just got back from Wales at 2:20a.m. BST (no, not bull **** time) - British Summer Time. Drive to 3 hrs, twice the regular time because of road works and associated diversions. Can't help noticing how noisy the stock tyres are on anything other than smoooooth surfaces. I was almost quiet on the latest black top but older open grain surfaces, RRRRRRR! Can't wait to sacrifice a few mpg and get some new shoes on Poppy!
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Not to be confused with "British Standard Time." :D
    RCO, kithmo and Prodigyplace like this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yup, that's UTC now! Don't ya just love all these acronyms???? o_O
  18. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Michelin is hard to beat....they cost and they deliver
    Continental are getting good also
    RCO likes this.
  19. Prodigyplace
    12,713
    11,848
    Central Virginia
    What tires do you have? I know some people said the Toyo tires were especially noisy. The Bridgestone Ecopias are not very quiet either.
  20. Samprocat
    491
    297
    Lincoln, NE
    I have Bridgestone on my Prime and I just hate them
