10,8 volt on aux batterie
Discussion in 'Gen 2 Prius Main Forum' started by Flying White Dutchman, Jan 27, 2008.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    Most "sealed" batteries are not really sealed, and you can indeed ad DISTILLED water if you carefully remove the covers. Having said that, there should be no need to ever add water to a "sealed battery" during it's normal life. If you live in a very hot climate you might have an exception. Batteries that are low on water either have a problem with the battery or they are getting overcharged by the alternator. I suggest again,,get the battery and perhaps the charging system tested.
    Icarus
  2. parky
    parky New Member
    51
    montana
    The Delco is in my truck also.
  3. icarus
    4,884
    976
    earth
    I think that the Delco batteries are "maintence free" lead acid batteries that can indeed have water added. The optima on the other hand are a gel-cell battery and are truly sealed, and cannot have water added. (If I'm right about the optima's that is why you can run them on their sides, or upside down without damage, something you can't do with a "flooded cell" battery
    Icarus
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Sorry I should have added if you don't know how to correctly use a battery charger don't connect one to your battery.
    No one said you should stand over an open battery while you connect the battery charger cables to the terminals while they are live. Always connect the cables while the charger is turned off and with a heavy cloth over the battery. Once connected switch on the charger then while the charger is charging the battery it is safe to carefully remove the cloth and look inside but do not disturb the connection to the battery in doing this as the gasses given off from the battery are explosive if exposed to an ignition source.
    For that matter you should always cover a battery with a cloth when charging as it is always posible for a lead acid battery to explode while charging if exposed to an ignition source. An other sign of a shorted cell is low electrolite in all the other cells due to boiling off.
    Just buy a new battery.
  5. darelldd
    6,059
    389
    Northern CA
    Sorry to be posting this in all three currently-running battery threads, but what the heck!
    I just finished up installing an Optima in the Prius (And Rav4EV, as well!). Went well.
    Prius Optima Aux
  6. fish_antlers
    fish_antlers New Member
    200
    Ca
    DO NOT LISTEN TO THIS PERSON'S ADVICE! YOU WILL GET SERIOUSLY HURT.
    NEVER COVER A CHARGING BATTERY.
    BATTERIES GIVE OFF HIGHLY EXPLOSIVE HYDROGEN GAS AND MORE WHEN CHARGING. YOU WILL TRAP THESE GASSES. NEVER COVER A CHARGING BATTERY.
    JUST DO NOT LISTEN TO THIS PERSON'S ADVICE! i CAN'T BELIEVE WHAT I AM READING.
  7. patsparks
    10,664
    567
    Note: These instructions were written for general automotive type battery chargers. They meet the standards of UL and CSA. The first part covers battery, general electrical, and charger safety issues. Below that is a section on hooking up and using a charger. Last a trouble shooting section.
    Download owners manual/charger instructions in PDF format, Instructions English.pdf, Instructions French.pdf.
    Speci
    Instructions for your Safety.
    BATTERY WARNINGS
    DANGER! RISK OF BATTERY EXPLOSION FROM HYDROGEN GAS. MAY RESULT IN BLINDNESS, SERIOUS INJURY, PERMANENT DISFIGUREMENT AND SCARRING.
    Batteries generate explosive hydrogen gas, even during normal operation. People have been injured by battery parts flying in an explosion. They can explode under normal operating conditions, such as starting your car. They can explode under abnormal conditions, such as jump starting, or if short circuited by a tool. They can explode in a parked car or sitting on a table.
    To help reduce the risk of these dangers and injury, it is of the utmost importance that each time before using your charger, you read and understand this manual, and any warnings and instructions by the battery manufacturer. Follow these instructions exactly.
    TO HELP REDUCE THIS RISK:
    1. Wear Personal Protective Equipment
      • ALWAYS wear complete eye protection (THAT PROTECTS EYES FROM ALL ANGLES).
    2. Avoid Flames and Sparks Near Battery and Fuel
      • ALWAYS keep flames, matches, lighters, cigarettes or other ignition sources away from battery.
      • DO NOT put flammable material on or under charger. DO NOT use near gasoline vapors.
      • Make sure charger clips make good contact by twisting or rocking them back and forth several times. The second clip connection MUST ALWAYS be made away from the battery. ALWAYS plug charger into an electrical outlet AFTER all connections have been made. See OPERATING INSTRUCTIONS.
      • If necessary to remove battery from vehicle to charge, ALWAYS turn off all accessories in the vehicle. Then ALWAYS remove grounded terminal (connected to car frame) from battery first.
      • A tool touching both battery posts or battery post and car metal parts is a short circuit and will spark. When using metal tools on or near battery be extra cautious to reduce risk of short circuit, possibly causing a battery explosion. DO NOT drop a tool on battery.
    3. Reduce Explosive Gas (hydrogen)
      • Before connecting charger, ALWAYS add water to each cell until battery acid covers plates to help purge extra gas from cells. DO NOT overfill. Battery acid expands during charge. After charging fill to level specified by battery manufacturer. For a battery without removable caps (maintenance free battery), carefully follow manufacturer's instructions on charging.
      • Some sealed maintenance free batteries have a battery condition indicator. A light or bright colored dot indicates low water. Such a battery needs to be replaced, not charged or jump started.
      • Charge battery with caps in place. Most U.S. batteries are made with flame arresting caps. DO NOT pry caps off sealed batteries. Place wet cloth on batteries with non-flame arresting caps.
      • Be sure area around battery is well ventilated before and during charging process. NEVER charge in a closed-in or restricted area.
    4. Stay Away From Battery When Possible
      • NEVER put face near battery.
      • ALWAYS locate charger as far from battery as DC cables permit.
      • ALWAYS keep other people away from the battery. They are not wearing safety glasses like you are.
    5. Avoid Contact With Battery Acid
      • Battery posts may have acid corrosion. DO NOT get corrosion in your eyes. Avoid touching eyes while working near battery.
      • ALWAYS use a battery carrier. Carrying a battery by hand may put pressure on its ends, causing acid to be forced out vent caps.
      • ALWAYS have plenty of fresh water and soap nearby in case battery acid contacts eyes, skin or clothing. If battery acid contacts skin or clothing, wash immediately with soap and water. If acid enters eye, immediately flood eye with cold running water for at least fifteen (15) minutes and get medical help immediately.
      • In very cold weather a discharged battery may freeze. NEVER charge a frozen battery. Gases may form, cracking the case, and spray out battery acid.
    6. Avoid Overcharging Batteries
      • The non-automatic (manual) battery charger models can overcharge a battery if left connected for an extended period of time, resulting in loss of water and creation of hydrogen gas.
    7. Follow Other Manufacturers' Recommendations
      • Before using charger, read all instructions for, and caution markings on: (1) charger, (2) battery, and (3) related product using battery. Follow their recommended rate of charge.
    From Battery charger instructions - general automotive
  8. fish_antlers
    200
    Ca
    Again.... don;t listen to this guy... now he's just cut 'n pasting.
    Batteries are unbelievably dangerous and can cause you great physical harm..- I know from first hand experience and from co-workers (I happen to be a licensed electrician)
    Please do yourself a favour and DO NOT listen to Internet advice on this. Talk to an EXPERT in person.
    This is EXACTLY the sort of topic on the internet that could really get someone HURT VERY BADLY.
    It shouldnt be allowed to continue. :mad:
  9. icarus
    4,884
    976
    earth
    Fish Antlers, I believe you are the one that need to do a bit of reading:
    A Towel over the vent caps of a battery will A: prevent a dropped tool from arcing between terminals, B: will keep acid from splashing if the caps are damaged and ergo keep it out of your eyes, and C: allow hydrogen to escape safely. All charging batteries need ventelation. Please don't spout info without attribution, especially where peoples safety is involved! At least Patsparks and myself have some documentation to back up our opinions!
    Once more, I refer you to the following sites, do all of us a favor read and understand.
    Deep Cycle Battery FAQ
    http://www.batteryfaq.org/
  10. Flying White Dutchman
    4,376
    313
    take a deep breeth
    take it easy
    no batterie is going to blowup:D
    my is dead already:eek: Dide on my this morning:eek:
    RIP feb.2008
  11. patsparks
    10,664
    567
    Did a doctor pronounce it dead or are you just going on the way it doesn't do much any more.
  12. Flying White Dutchman
    4,376
    313
    no hartbeath:eek:
    the prius dashlight dont liteup
    the doors wont open.
    its dead.........:eek:
    put it on a charger and started the car seconds after that.:cool:
    prius when started is not in need of this battery;)
    dont send flowers:D its going to be reclycled and live a new life
  13. patsparks
    10,664
    567
    It may come back as some roof flashing or fishing sinkers. What a life!
  14. Flying White Dutchman
    4,376
    313
    and then it can say
    "in my previous life i have bean a prius battery"
    and the fish wil say "aaaaaaaaaaa" amazing
  15. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Did you leave the parking lights all night as you alluded on another thread that you were planning on doing?
  16. Flying White Dutchman
    4,376
    313
  17. Flying White Dutchman
    4,376
    313
    ok a update,
    i stil am driving with the same battery that left me standing a few days before.
    i went to the dealer and dit a resistence check and came out OK?
    then i when to a specialized battery car dealer and told me that the battery needs to be replaced.
    THEN i whent to the shop and got me a battery tester and checked it myself
    it read out was WEAK/BAD and advise was to recharge whit a small charger (300mAp's)
    I got it connected now and see what happens its currenly discharging and then starts the charging again.
    the dealer also told me that when the car is not drivin for 30min a day ( aroudn that ) and the car is maybe left standing for weeks the battery needs to be disconnected.
    Realy most poeple drive the car almost every day
    i wunder if there are poeple that have a prius more then 2 year of age and only drive it one's a week for short distance and dont have this problem
    must say that its frizing here right now so maybe the battery cap is lower
    My previus car stands stil for weeks even monts and dont have any problem there...
    i have read in this topic http://priuschat.com/forums/prius-main-forum/41970-battery-dead-yet-again-12.html
    post 111
    that there is a nown problem with the JBL draining the car battery
    so maybe i need to test that!
  18. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It sounds like your dealer does not know and/or does not care. Get a new battery
    If I read correctly, your dealer is telling you to drive the car every day?
  19. Flying White Dutchman
    4,376
    313
    yes kind a
    when i dont drive the car often then te battery is not charged good and over time it wil faile!
    firts it was under warranty
    then the battery needs to stay over there for 1 night before any thing can be sure
    and now the battery is OK ......
    ii think someone is trying to get around the warranty replace:cool:
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Sure sounds like it. If the battery store tested the battery and told you to replace it, but the dealer told you to drive it every day, I'd sooner believe the battery store
