10 K Service, less than impressed! dealership misery!
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Apr 23, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    The problem seems to have resolved itself for now. As I was driving home yesterday, I heard a voice say, "software update completed." I parked the car overnight, and today, I'm not detecting any battery drain.
    I just wish that Toyota had decided to be more honest about this.
    bisco and Mendel Leisk like this.
  2. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Looks like you have entered in The Twilight Zone ...:confused: i did not know that the 2024 had a mind of it's own !
  3. Mendel Leisk
    41,463
    Is this with that new battery?
    Louis19 likes this.
    51,946
    our hybrid camry has been at the dealer for over a week with a leaky windshield, and will be there for undetermined amount of time do to parts availability.
    i got a free loaner when i brought it in, toyota is paying for everything. that's how it should be.
    daisy555 and Louis19 like this.
  5. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Now I need to figure out how to add my vehicle back into the app. It says, "not compatible" or something like that. The support line is now closed. I'll have to try later.
  6. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    I haven't received the new battery, and I don't know if it will work anyhow.
    But I'm fairly certain that when a major software update is happening, it can drain the 12V battery quite rapidly. In fact, just before the end of the latest update, my battery went dead after only 2 hours of being parked.
    Now that the update is finished, the parasitic drain has all but disappeared. Last night the battery voltage was 12.4V, and this morning it's around 12.2V.
    Gokhan likes this.
  7. Mendel Leisk
    41,463
    I would measure that, with a regular digital multimeter. Until you've got definitive measurement, you're mostly whistling past the graveyard.
    Neither of those numbers is very good; not sure you're out of the woods yet. What date did you drive the car off the the dealership lot? Maybe get it check with an electronic battery tester. One example is Solar BA9.
    #47 Mendel Leisk, Apr 27, 2024
  8. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Not sure what you mean. Those numbers look good to me.
    Remember, the voltage while the car is running is about 2V higher than when it's stopped.
    I took possession in the first week of January. I tend to believe that the battery tested OK twice, If I had insisted on a new battery, I would be a real A-hole, and it wouldn't have helped anyhow.
    I just wish Toyota were more transparent about their software updates. All you get for an indication is a rapidly-depleting battery. And an easily missable voice message, saying "software update complete."
    #48 Paul Gregory, Apr 27, 2024
  9. Mendel Leisk
    41,463
    For an AGM in good condition, 12.7 is good. That's car off, first thing in the morning. 12.2 is "on the way out".
    Did the dealership ever divulge what phantom draw they measure? Or did they even measure it?
  10. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    They nodded when I mentioned that I had measured 340 mA drain. I'm sure they knew about it, but didn't want to tell me about it.
    Compared to what was happening before, I'll take 12.2V after parking for a day, any day.
    My old Gen 3 Prius went dead in about a week for as long as I owned it. That was because of a 50 mA drain. If I wasn't driving it for a week, I put it on a battery maintainer. Just a fact of life with cars these days.
  11. Mendel Leisk
    41,463
    This is an 8+ year old AGM Optima Yellow Top, installed in our ‘10 in September of 2015. Car had a good drive the previous day, then voltage measured first thing in morning:
    (Load test results also attached)
  12. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    It all depends on the voltage regulator. In the colder months of winter, the regulator delivers a higher voltage than on the balmier days we're currently having. If my car wants to charge the AGM battery to 12.4V, I won't argue.
  13. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    From what I’ve seen your voltage is in the range of the Gen 4 charging algorithms. The system considers 12.4 volts good. And after the car sits for awhile the gas tank vacuum pump kicks in so the voltage will drop to around 12.2 volts (depending on whether you put your fob to sleep and how many lights you have on after the car shuts down).
    With in a short time the battery begins to recover a bit and usually settles down around 12.38 or so. At least that’s what mine has done since day one.
  14. bisco
    51,946
  15. Doug McC
    1,079
    418
    Midwest
    2022 Prius
  16. Gokhan
    Gokhan Senior Member
    6,216
    2,465
    Paramount CA
    No, Gen 4 and Gen 5 use an EN LN1/BCI 140R/DIN H4 lead–acid battery.
    Doug McC likes this.
  17. Gokhan
    6,216
    2,465
    Paramount CA
    It would be interesting if the parasitic drain was caused by the software update. I wonder if others experienced it.
    I would be surprised if an LFP lithium-ion 12-V battery in a Gen 4 or Gen 5 Prius didn't result in error codes. Lithium-ion batteries have built-in electronic battery-management systems, and they would confuse the battery sensor in Gen 4 and Gen 5 Priuses.
  18. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    But again: this is what the dealership should be doing. Why oh why do consumers put up with this?
  19. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    Then, once again, Bisco sends someone seeking help, down a rabbit hole. :cautious:(n)
  20. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    I could be an infinite A-hole over this, but I will be dealing with each issue in it's own time.
