10 K Service, less than impressed! dealership misery!
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Apr 23, 2024.
  1. Mendel Leisk
    41,463
    I've never seen anything from Toyota, stating their reason for using AGM, but the consensus here was that being in the cabin was the reason: less chance of spillage (in an accident), or venting of noxious or explosive gas.
    Quite the flip-flop now. Maybe regulations changed, or they found a loop hole?
    I agree though, more'n likely the usual motive: cutting costs by cutting corners..
  2. Trollbait
    12,542
    Those are good reasons to use one. The less wear from deeper depth of discharge is also one when using a lower capacity battery.
    Good reasons aren't requirements though. AGM came out in 1980, and wasn't used in cars until later. Plenty of models had the starter battery in the cabin before then. Plus, Toyota would have to pay to have the venting even with AGM.
    The cost difference between AGM and a floodie is something that could show up in the MSRP.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    I called the service departments of two dealers to confirm the type of battery, because my battery maintainer had settings for flooded cell, AGM and lithium. They both told me it was AGM. No one would know for sure without dissecting the battery.
    51,946
    I think it’s on the battery case, not positive
  5. Mendel Leisk
    41,463
    If it was AGM I think the label would say?
    FWIW: an AGM can be charged using a smart chargers “regular” cycle; the only diff with AGM is you can charge at slightly higher voltage, and it’s advantageous to do so.
  6. Gokhan
    Gokhan Senior Member
    6,216
    2,465
    Paramount CA
    It says "never add water" on Prius AGM batteries. It says "add distilled water" on Prius flooded-cell batteries.
  7. Gokhan
    6,216
    2,465
    Paramount CA
    Since when do dealer part departments know anything about the internal construction of parts?
    GS Yuasa makes AGM (VRLA) batteries only in JIS sizes B20 and B24 (Gen 2 and Gen 3 Prius 12-V-battery sizes). They don't make any AGM (VRLA) battery in EN/BCI/DIN sizes.
    https://www.gs-yuasa.com/en/products/pdf/YUASA_Automotive_Battery_Made%20in%20Japan.pdf
    Automotive & motorcycle batteries|GS YUASA
  8. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    FWIW: You may actually want to research that a little more. Yes, you CAN do that. Is it the wisest choice? I’ll let your research answer that question for you.
    I’ve got an idea for you (since you’re convinced it’s an AGM): remove the battery from your car, turn it on its side and see what happens. Then report back to us about what you learn. This is, of course, assuming you actually have access to a battery in a 5th generation Prius. ;)
    AND you apparently still haven’t looked at this battery yourself. Interesting. Assuming you actually have access to it.
    #108 Doug McC, Apr 29, 2024
  9. Gokhan
    6,216
    2,465
    Paramount CA
    Actually the Gen 5 battery along with most their other EN batteries is spillproof as stated by GS Yuasa due to the double-lid construction.
    There is a 0% chance that it is AGM because the Gen 5 battery on its label explicitly states that it is flooded-cell ("add distilled water").
    #109 Gokhan, Apr 29, 2024
    Doug McC likes this.
  10. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    My point EXACTLY! So either there is no Gen 5 available to this poster, or…..?
    Gokhan likes this.
  11. bisco
    51,946
    that's because they don't want you to extend the life of agm, but want you to help flooded make it past warranty :cool:
  12. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    (n) Never let facts interfere with your beliefs (or at least that’s the current thoughtless pattern. OOPS, guess that’s supposed to “thought”, but reality creeps in once in awhile :whistle:). Paranoia runs deep, as they say.
    Gokhan likes this.
  13. Gokhan
    6,216
    2,465
    Paramount CA
    And the biggest examples are antivaxxers and global-warming deniers these days.
  14. Trollbait
    12,542
    The label also states "do not tip". Leak proof or not, flooded needs to be upright to work safely. AGM can be mounted on their sides, just not upside down.
  15. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The same dealers that have done a terrible job solving your problem? Why are you trusting anything they're saying any more?
    In fact, if they're convinced it's an AGM battery(it's not), they might not be testing it correctly. They should be using a DCA-8000 Battery Diagnostic Tool in the Advanced Battery Test Mode. They're supposed to use the scanning tool to scan both the VIN and battery barcode, but if they're manually entering the battery data, it should be the following:
    CCA
    Flooded
    285
    Customer Complaint - Yes
    It's been said a dozen times so far, but the battery in both the gen5 Prius and Prius Prime is a GS-Yuasa 345LN1-MF which is a variant of their Y6-355LN1. All the GS-Yuasa Y6 batteries are flooded.
    https://www.gs-yuasa.com/en/products/pdf/Y6_for_General_passenger_cars.pdf
    Trollbait, KMO and Doug McC like this.
  16. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    You probably realize this, but, you are probably confusing Paul (assuming “he” actually exists) with the facts.
  17. Mendel Leisk
    41,463
    From my CTEK 4.3 users manual:
    And this is from my older CTEK 3300 charger manual:
    I've seen other mention (can't find at the moment), that even rectangular case AGM batteries should use the regular charging program, that it's only the spiral-wound (6-pack style) AGM's that can benefit from the slightly higher charging level. Never the less, you can charge any-and-all AGM's with the regular program.
    #117 Mendel Leisk, Apr 30, 2024
    otatrant and bisco like this.
  18. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Sorry, it's just too much for me to believe that Toyota is giving us flooded cell batteries without telling us.
  19. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Do you even own a Prius Prime?
  20. Paul Gregory
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    You think I'm lying too?
