'10 Prius handles great in emergency...
Discussion in 'Gen 3 Prius Main Forum' started by tedjohnson, Dec 12, 2010.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    So, it is 12/11 at 7 am driving along a 55 mph 2 lane highway, when I start to see slide marks in the thin, almost unseeable icy coating on the road. Then a van is parked in the middle grassy area from a skid and an ambulance & Police are there. Next another car is against the guardrails on the right, this convinces me to slow down to 45 and join a group of 4 cars poking carefully along. This being a new car to me (got it in May), I had not gotten a chance to throw it into skids and practice ice driving yet, so I figure take it easy till I know the car better. FWD, brand new Blizzaks, lots of weight in the car ( Xmas tree and a pile of firewood) . Still people are having trouble yet the Prius seems solid on the ground. A big white 4 WD pickup comes up behind me, speeding like those brain deads do - he pulls out and passes me then steps on it spins out into the median, then fishtails across my side 2 lanes, smashes into the guardrail on the right and bounces off back into the righthand lane where I am attempting to slow as fast as I can without throwing the Prius into a skid (ABS works great !). I see there is no way I can stop without hitting his still sliding truck , so I cut the wheels sharply to the left and press the gas pedal to have the front wheels pull me around his vehicle - visualizing a crunched right fender and damaged right side as I would be scraping along his truck side. To my amazement ....No Crunch, No Bump, No Anything - the Prius handled perfectly missed him by an inch as he continued sliding out into the passing lane. What a great car !!!!!! Lucky me :)
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    The problem with idiots with 4WD is they don't realize they have the same 4 wheel brakes and tires the rest of the world have, and driving like a fool is equally dangerous regardless if you have 4WD or not. 4 wheel go means nothing if you can't stop...
  3. donee
    donee New Member
    2,956
    197
    Chicagoland
    Good Driving Ted !
  4. hpartsch
    hpartsch Member
    102
    pa
    nice, well not for the other guy.
    He probally also did not have stability control like you do, I think a car with stability control can outperform any fwd non stability control vehicle, especially in sliding condition as you described.
  5. bisco
    49,463
    i'm requesting the removel of these scary near fatal prius accident threads.:rolleyes:
  6. boppo
    boppo Active Member
    799
    138
    Owego, NY
    :rockon:
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I think this is a 'scary near fender bender' thread but we can't be too protected from distressing sheet metal bending. :banplease:
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    tedjohnson,
    How much of your ability to go zigging and zagging on the slippery
    stuff would you attribute to the Blizzaks?
    Just wondering how they helped. I've got a set on extra rims, but
    thankfully no reason to mount them in Ballamer... yet. :rolleyes:
  9. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Not sure, but I know they sure helped... Ted
  10. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    You can credit the the good handling Prius to your Blizzaks plain and simple.:cheer2: H
  11. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    :rockon:
    The only thing that would make your story better: "I rolled down the window and gave him a one finger salute as I passed by."
  12. fuzzy1
    10,167
    I would say, a lot of it. My half-worn-out OEM Ecopias were terrible in Seattle's recent snow, and would not have successfully pulled off this maneuver.
    But I was quite happy with how the ABS/TC/VSC made excellent use of what little traction was available.
  13. Tideland Prius
    16,152
    Good thinking (quick too I suppose) on your side. I would have never have thought to step on the accelerator as I attempt to go around him. I would've either continued braking or release the pedal slightly in an attempt to give more traction to the wheels to turn the car instead of brake.
  14. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    Thin sheet of ice on road??? I don't understand....
  15. Beauregard
    Beauregard Member
    89
    25
    Colorado
    2015 Prius c
    You practiced a critical element of emergency performance driving.
    You're often times much better off to drive around a hazard that to try and stop short of it.
    The trick here is in your vision. Look at where you want to go, not at what you're trying to avoid.
    Quickly move your eyes to an escape route, and steer through the danger zone in a fluid motion.
    The inexperienced and untrained tend to look right at the hazard with wide eyes and lock up the brakes, usually resulting in a collision. Trained drivers will always be thinking of escape routes and won't pin themselves in. This means always being aware of the traffic and roadway lanes around you. It's basic driver training for emergency responders.
  16. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I've been in a few close calls in my Prius where I had to swerve and accelerate. Nicely done. Welcome to the cluuubbb.
  17. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    It was strange.. like a light snow had fallen and just coated the tops of tiny bumps of the tar, and it did not look icy but sure was - fooled a lot of drivers.
  18. Ted in Olympia
    Ted in Olympia New Member
    84
    Olympia WA
    I would say this was 35% Prius and 65% good defensive driving. The main thing is that you slowed down and looked for trouble before it started. Great Job!
    The week I got my Prius I had a deer run right out in front of me and I got to admit the brakes/ABS worked great; neither the deer or the Prius got hurt.
    TED
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Smart move to slow down early. The VSC on the Prius can make it hard to really appreciate how slippery the conditions have become. You don't get a lot of the early warning squirrelliness that we had with older cars. It's a good thing, but something your need to appreciate.
    As for the tires verses VSC debate, both contribute to good winter handling. With bad tires, there isn't much VSC can do to help. The tires are the only thing that generates friction with the road. Without friction, you are no longer driving, you are just along for the ride.
    Tom
  20. Penny's Dad
    421
    46
    Orlando Fla
    I was actually pointing out that it would be very rare to actually see any ice on the road where I live...that said I appreciate the clarificaiton because if for some reason I ever did have to drive on an Icy road I would be very ill prepared. You cold weather people certainly have skills that I have never had a chance to develop. On the other hand I can cool down a 130 degree interior in 5 mins.
