100,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by efusco, Mar 6, 2007.
  1. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I bought my 2006 Package 7 silver Prius in January 2008 with 33,400 miles on it.
    Here it is three years later and I’m still happy with it. Basic maintenance and a few learning curve issues and one new set of tire (Bridgestone 80,000 tread ware rating of 600) and I just rounded 107,000 miles on my way home to western NY from a monthly meeting in Worchester MA.
    I’m averaging “real world driving†mileage of 49 MPG in the Spring, Summer and Fall and 34 MPG in the Winter.
  2. pjam
    pjam New Member
    31
    Nashville
    my personal post of the year. great info!
  3. Grichard
    Grichard Junior Member
    16
    florida
    2006 base model purchased October 2006. 104,000 miles mostly on E10.
    So far, only wiper blades, right front wheel bearing, and oil/filter changes. Replaced tires at 40K with Michelins. Still on them.
    Amazing!
  4. smtrader
    smtrader Member
    105
    Cerritos, CA
    I have 131,000 miles on my 04 Prius...looking good until yesterday! 4 lights came on (VSC, yellow(!), Check Engine, Red triangle, plus one on the upper corner of my screen). Took it to the dealer and they told me this morning that "one of the cells" in my battery is "going bad"!! Ouch...am I looking at $4K to replace the entire battery???? :(
    Anyone have any alternative suggestion? Are there after market Prius batteries? :D
    Thanks...I'm still in sticker shock as I had NO symptoms or warning about this potential BIG bill coming my way!
  5. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Do a search on battery replacement or similar keywords and you find various sources for replacement options including wrecking yards, Luscious Garage (in San Fransisco), and somewhere back east that sells refurbished batteries. If you are not mechanically inclined you may want to make a trip to Luscious. I'm sure they can fix you up for MUCH less than the dealer will. You can pay as little as about $700 to $2.5k to have this fixed if it is just a battery problem.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    You are in California so it should be under 10 years / 150k miles warranty. You should get a free pack.
  7. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    anybody know if the gen 3 1.8 ice has a timing belt that needs to be replaced? my '83 camry had 4 replacements in it's 295,000 miles.....
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    No belt. It's a timing chain.
  9. smhennes
    smhennes Junior Member
    Indianapolis, IN
    Just curious, where do you live and how fast do you drive on the highway?
  10. jqmello
    jqmello Junior Member
    70
    DC
    just bought an '05 base model prius with 92,600 miles - it's going to be my wife's primary driver, her commute is 25 miles each way, mostly highway driving at 40-60 mph. We've put 50 miles on since yesterday afternoon and are still watching our average mpg climb - it's at about 48 now.
    What with ex-Shell officials predicting $5.00 gas we thought we'd try to be prepared. The used market is tough right now - lots of high mileage vehicles outside of our price range. Three competitively priced Prii that we were looking at sold before we could get to them. Do people get rid of their cars when the main traction battery is about to go out of warranty?
  11. smtrader
    smtrader Member
    105
    Cerritos, CA
    That explains it! I just got my car back after 2 days and a new battery...and I thought they were just being nice to me! :D Either way, I'm tickled. The only thing I paid was a 2-day rental. I'm a happy camper, for at least another 100K miles!! Thanks.
  12. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    It should last a lot longer. Can you describe your commute? Do you live on top of a hill? Do you park outside? Did you install EV button? If yes, how do you use it?
  13. zenMachine
    zenMachine Just another Onionhead
    3,355
    299
    Finally joining this club... :)
  14. smtrader
    smtrader Member
    105
    Cerritos, CA
    My commute is on flat Southern Cal freeways for about 30 miles each way, sometimes with traffic and sometimes without (I have irregular work hours). Flat everywhere, no hills; and car is always garaged. NO EV button. I'm surprised that my battery only lasted for 131K miles!! Anyone have any ideas to sustain them longer???? :D
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    As usb says, typical is much longer life so I would not lose any sleep over the initial battery experience. That said, heat is bad for battery longevity. I avoid high cabin temps by keeping my windows shielded and cracked open for ventilation when the car is parked, and I cool the car with AC into the high 70's F during hot summer driving.
  16. elect1960
    elect1960 Junior Member
    198,000 miles 2005 average mpg is 48 to 53
    I do a 69 mile each way commute
  17. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Avoid often draining of the pack down to 2 purple bars. Those deep discharges take a way a lot of cycles under normal hybrid operation. Depending on your traffic pattern, this may not be avoidable. If you think the jam is going to be long and need to run AC, you can always press the accelerator harder to run the gas engine for acceleration and then regen to "even out" the electricity to run the AC.
    As SageBrush pointed out, temp is also another factor. You can park indoor at home but maybe not at work. Tinting and leaving the window cracked open should help.
    Avoid aggressive acceleration in stage 1 (during warm up). Prius will aggressively use the HV battery to avoid ICE from running hard before the catalytic converter warmed up. This is intentionally done to reduce emission.
    I created a page with more information.
  18. zenMachine
    3,355
    299
    Bought: March 2007
    Latest tank avg: 48.0mpg
    Avg overall: 46.0mpg
    City commuting 80%, road trips 20%.
    Regular maintenance every 5000 miles.
    Changed to Michelin tires at 60K, love them.
    12V battery died a couple times (forgot to turn off SKS for long layoff period) but seem to still work fine.
    No problem whatsoever. Best car ever owned.
    Q: what 100K maintenance service should I get? thx.
  19. jqmello
    70
    DC
  20. smtrader
    smtrader Member
    105
    Cerritos, CA
    Nice table!! Thanks. I'll try what you said though I'm not entirely sure how to suddenly accelerate in SoCal traffic (aka parking lot) far and long enough to get the gas engine engaged...without hitting the guy in front of me. :cool:
