100,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by efusco, Mar 6, 2007.
  1. Silver Pine Mica
    Silver Pine Mica Junior Member
    48
    22
    Columbia, Missouri
    My 2006 now has over 145,000 miles and has recently had its first non-routine maintenance that I can remember with the replacement of wheel bearings and coolant pump, plus coolant drain and fill of both coolant loops. Total cost ~$1,100.
    I am also changing over to a reusable engine air filter:
    Upgr8 U8701-3902 Hd PRO OEM Replacement High Performance Dry Drop-in Panel Air Filter Red
    Previous routine maintenance: spark plugs and PCV valve ~$40
    Plus tires and oil/filter changes
    windshield wipers
  2. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I finally crossed over the 100,000 mile barrier just after Christmas :)
  3. Josh Imholte
    Josh Imholte Junior Member
    30
    Just joined the forum and figured I'd post my novel of my Prius experience.
    2006 Prius Touring w/ Nav
    119K miles
    Bought it from Toyota Dealership that only had 1 owner. Bought it in 2014 that only had 55k miles on it at the time.
    I've replaced 12v battery once
    Inverter Water pump replaced at around 90k miles
    Combo Meter also replaced around 110k miles
    Just replaced the Hybrid Battery at 119k (think age killed the beast) Bought remanufactured battery from Cardone and local mechanic installed. Battery has warranty 3 yrs/36k miles.
    I'm averaging about 45 mpg, with the new battery and possibly because I'm trying my hardest to see what I can get, I'm averaging 48MPG this tank with replaced Hybrid battery.
    Replacing both HID bulbs that I just bought, should be coming in tomorrow. Ive been riding with only 1 headlight for a while so figured its time to replace those.
    Also replacing cabin air filter since Im tinkering, doubt thats ever been replaced.
    I don't think the brakes have ever been replaced and working perfectly still! (knocks on wood)
    Stock JBL speakers and radio all working perfectly.
    Have oil religiously changed every 3k miles
    I'm really surprised how well the interior holds up compared to some newer low cost cars like Kia. My steering wheel barely looks worn and I've never had a cover on it. My leather interior has no tears and barely any wear. Although the original owners opted for this special gel built into the leather seats that lets you glide across the leather easier so it doesn't wear out as much....they spared no expense! ;)
    Still owe about $4k on her but will be paying that off in March w/ a bonus. Can't wait to finally be without a car payment for a little bit.
    I feel 119k is low miles for a Toyota car, but the age definitely got to my Hybrid battery. Was hoping to pay it off before I ever needed to do that but its a done deal now. I hear the really only major thing to worry about aside from normal maintenance is the brake actuator so fingers crossed that doesn't pop up soon.
    I'm not gonna lie I was a little shaken up when my hybrid battery failed recently but I gotta say, I was still able to drive the car around where I needed to go till I took to shop, and once I decided what I wanted to do and they ordered the part, its crazy how just plug and play the Hybrid battery is compared to trying to rebuild and engine or transmission.
    Having had much newer cars in the past, I was truly surprised how much tech this 2006 Prius had. Granted, this Prius was fully loaded so that may vary but I've been happy with what this car had built into it that long ago.
    I kinda like the Prius V...in a couple years never know I may just look into that and keep this one in the fam as a 3rd vehicle. Prius Prime sounds cool too! Hope this helps! I hope my 06 is still solid for me to post on the 200k club!
    #843 Josh Imholte, Jan 30, 2018
  4. Scott56
    Scott56 Junior Member
    40
    27
    Alabama
    Here’s my 100k mile rollover on 2/12/18. My 07 is 11 years old now. It gets 47mpg in the winter and last summer it was averaging between 51/52 mpg. Original hybrid and 12v battery still working fine. I’ll replace with green bean remanufactured hybrid battery once mine fails. I’ve seen online one 1997 prius still driving around on the original hybrid battery 20 years later so its worth sticking with for awhile.
    Venluckey and Josh Imholte like this.
  5. JC91006
    16,748
    8,553
    With your low mileage, it's better you buy a new Toyota battery when yours fail.
    Or buy a reconditioning kit now before it fails
    Raytheeagle likes this.
  6. Josh Imholte
    30
    Agreed, start looking at your hybrid battery options head of time Scott56 wherever you live to know what options you have when the time comes. Fingers crossed, you get as much life as possible out of yours. I was a little blindsided that mine needing a need Hybrid battery at only 120k miles on my 06. From what I read its not the miles that gets it, its the age.
  7. Weaktwos
    Weaktwos New Member
    San Antonio
    I'm new to Prius Chat, but I've got a 2005 Prius with 165000 miles on it. The only things I've had to replace on it were the 12v Auxiliary battery, the tires, the breaks, and standard maintenance. I am getting ready to buy a Prius Prime shortly, as I'm ready for a new car updated audio and cellular integration features, as well as safety features. I'm looking forward to using less gasoline.
    Usually, I get 47 mpg in my normal commute miles. The hybrid battery is still going strong.
    Josh Imholte likes this.
  8. Venluckey
    Venluckey New Member
    Manufactured 11/03
    154, 235 Miles. Bought it used after it was stored for 2 years (guy died in his house and car was in garage, he was not discovered for 2 years). Bought it in 2016, had 57K miles on it, and paid $11,2300.
    Have hit tons of animals with it due to it being quite and living in the country. (2 Birds, 2 Dogs, 1 Alligator, 1 Raccoon, 1 possum) Have had following replaced due to animal strikes: 4 front bumpers with plastic grill guards, 2 radiator supports, 1 radiator, Both head lights, 1 hood latch). Missing the plastic under engine covers, destroyed them when I hit the gator, never found a good replacement.
    Was hit bay a pickup while parked, Had following changed due to that accident (Passenger front and rear doors and speaker wiring harness, Passenger front panel quarter panel).
    Recalls performed: Dash recall for it just turning off while driving
    Parts replaced: Oil filters always Toyota brand, Cabin filers (now K&N) engine filter (now K&N), Oil (Valvoline) , inverter coolant pump and coolant, Radio antenna (original was stolen at Walmart), Tires (Firestone brand works pretty good around here), MFD was replaced last month due to mine just went black.
    Uses: travels 42 miles 5 days a week for work. Used for long trips due to good gas mileage.
    Still get around 43 mpg if driven at speed limits, Cruise control and stereo functions still work from steering wheel.
    Other than all that, I would buy a newer Prius in a heartbeat.
    srellim234 likes this.
  9. PriusTFTW
    PriusTFTW Junior Member
    Socal
    Just hit 124k....
    orenji likes this.
  10. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    144,203 miles and no major issues. I haven't been on the forum much lately - this darn car is just boringly (wonderfully) uneventful. Might have lost 2-3 mpg average but I stopped trying hard at chasing mpg a long time ago - so it could be the driver more than the car.
    Other than the usual oil & filter changes, air filter changes & tires, I've done the transaxle fluid and the dealer replaced a rattling water pump. They had already done the inverter pump recall separately. Tire shop checks the brakes at every rotation and I've yet to need a brake job.
    It's been so reliable I feel like I've gotten complacent about things that should be done at the 100K+ stage. Might need to tackle the spark plugs one of these days.
  11. gamma742
    gamma742 Member
    178
    73
    Luxury
    You have the original Spark Plugs in there?
    Data Daedalus likes this.
  12. don_chuwish
    823
    190
    Southern Oregon
    As best I can remember, yes. But when I started watching YouTube videos about it I thought 'this looks really familiar'. Might be from when I did it on my Odyssey though. I'd check my Toyota Owners service record but the website seems to be unavailable the past two days I've been trying.
  13. don_chuwish
    823
    190
    Southern Oregon
    Too funny, I finally got back in to my service history and see that I "Replaced spark plugs, Replaced PCV valve, Changed ATF" in June 2016 at 119,600mi. Well now I have an extra set of plugs on hand.
  14. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Other than regular maintenance items, tires, oil changes 12 volt battery etc, my first failed part was the coolant pump at around 96000 miles. I hadn't done the recall so I got it done free at the 96000 mark. Mild climate on the central California coast so I hope the Hybrid battery will continue to perform for a long time. Best car i've ever owned!
  15. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
  16. Janis
    Janis Junior Member
    118000 miles Won't part with it though it has met more than a few poor drivers. Just because my 05 is small is not a reason for denting it but parking lot drivers are terrible. First real problem began last August with the mileage dropping significantly. Now in mid winter down to 22mpg. Toyota dealer says the hybrid batteries can't be checked which sounds odd to me. Would like to replace the 12V if I can find a list of online, reputable battery dealers. The local mechanic says no problem with the 12V but I have my suspicions.
  17. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The "best" 12 volt battery is at the dealer and has a 84 warranty. (Be optimistic, it might make it 84 more months!)
    Optima YellowTops have a good reputation and are direct fits if you have the Smart key System.
    www.amazon.com/Optima-Batteries-8171-767-DS46B24R-YellowTop/dp/B006VFEJJQ
    Several chain Auto parts stores (NAPA, etc.) have a house brand battery. There are similar batteries online. No idea who makes them.
    www.amazon.com/Delphi-BU9051P-51P-AGM-Battery/dp/B01DLGRPPM
    You do not list where on Earth* you are, so I can't say what is local.
    *I am just assuming Earth, what do I know?
    jerrymildred likes this.
  18. Janis
    Janis Junior Member
    Thanks The last battery purchased was not from the dealer and less expensive. That was five years ago in West Michigan.
  19. Janis
    Janis Junior Member
    What is a reconditioning kit? Something I could talk a local mechanic into using?
  20. JC91006
    16,748
    8,553
    I don't recommend buying one of these kits for cars over 10 years old. The cost of the equipment ($700) will be around 20% of the car's value if it's over 10 years old. It also doesn't prevent the battery from failing, so you could end up with the equipment and buying a new battery later. It just helps "prolong" the battery from failing.
    But you can get more info at hybridautomotive.com. They make the reconditioning "prolong" equipment.
    kerbear54 and kenoarto like this.
