100,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by efusco, Mar 6, 2007.
  1. Pruiz
    Pruiz New Member
    Metrowest
    Just found this thread.
    -2007 Prius bought original in 2006 since my new-born and the 1992 Two door Saab 900 don't work well together.
    -How do you drive a hybrid?! was a common question I would get back then
    -135,000 miles now
    -Hybrid Battery failed right before 10 years, 100K so got a new one courtesy of Toyota
    -Always parked outside here in the Boston area
    -New Tires, Trunk latch failed, replaced 12v once, hole in the carpet from my heel, had rust in the upper trunk frame and so water would pile up in spare tire compartment (fixed by having it spot welded), front hood latch is pretty shot but I probably open it 4 times a year and can still get it closed, exhaust replaced, both key fobs lost (first one lost after 4 years, second one after 11 years so had to buy two new ones), various little things here and there but overall, a trooper. Now what did I do with all of that money I have been saving all of these years?!
    Note that I have a Mach-E on order to replace the Prius because let's be honest, the Prius is not going to die on its own,
  2. MRK0017
    MRK0017 Junior Member
    ITA
    I obtained my Gen 2 black Prius from my father as he "upgraded" to a big ugly BMW after the dealer brainwashed him. This Prius has 260k Km (that is around 150k miles). It still works really well, no problems to speak of. Only issue I ever had happened after a detestable scumbag whom I hope will die a painful death stole my catalytic converter one day (yes, it happened duringthe day on a busy road too). This car is simply a marvel, I like it so much. It's so well thought out, everything is simple to use and easy to reach, unlike on the aforementioned big ugly BMW. It's full of neat little things that make driving it really enjoyable. My father always got it maintained at the dealer with regular schedule, and he replaced the hybrid battery 2 years ago IIRC. As of right now, the car is just perfect.
    Anyway, this car is ancient, but it doesn't feel nasty and outdated like other cars from that age. I guess it was way ahead of its time when it came out, and mine isn't even the best trim level, so no fancy cd-changer, MP3, or keyless entry for me, I can only imagine how nice the higher trim levels would have been. And also, if the ancient model is so damn nice, I can't even imagine how cool the newer Prii (Priuses?) must be. When I feel like it I will add the bluetooth module I bought on ebay, but I still have fun making my own CDs like it's 2001, also, my father got hands free installed aftermarket some time ago, so I can answer to calls like on a modern car.
    That being said, I'm going to take good care of it and I hope it will last a very long time.
  3. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    it will last a very long time with that attitude! Happy for you and my gen 2 does not feel as old as it is, like you mentioned. Check out all the preventative maintenance/upkeep in general that you will find throughout all the forums!
    Therese Rudolph likes this.
  4. Tombukt2
    Tombukt2 Senior Member
    12,941
    2,322
    Durham NC
    Ha I do not even have interest in the car gen 1 or 2 unless it's brought to me with over 100K . Period. 220K even better. 1NZ bottom end falling apart? Ha break INS. I put up hi PO blocks up dry no slothing build oil all over everything to get pistons in bored etc . Put up almost dry. At crank the first few travels up n down bore rings seated .literally minutes . Welp let's for drive an hour now. Doing this since the 80 wen we were told oh it all be instant engine fail .Not
    SM-A715F ?
  5. davedog
    davedog Member
    403
    SF Bay Area, CA USA
    2005 Prius with 216k miles. Original owner. I've replaced the original battery with a rebuilt used battery. Safety issues with my headlights going dark quickly are making me consider a new car. I think it'd be more expensive to repair than it's worth.
  6. Tombukt2
    12,941
    2,322
    Durham NC
    Hid? Change over to led and problem disappear the day I replace a car for headlights is thee day...he he
    SM-A715F ?
    kenoarto likes this.
  7. psychoo
    psychoo Junior Member
    Czech
    I won't be driving for three months now. The Prius will be standing in the garage. Will the hybrid battery fail? I will be far from home and I have no way to drive. The 12V battery is new and charged and the keyless is off.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    Hybrid battery should be OK. But, if you can't keep the 12V on a trickle charger, I suggest disconnecting it or it will be dead when you get back in spite of turning off the keyless entry.
  9. Tarams
    Tarams Junior Member
    58
    17
    North Carolina
    Sorry, realized I replied to wrong post!
  10. Tarams
    58
    17
    North Carolina
    My 2005 Prius sat during covid shut down, was running perfect prior, can't recall how long it was unused but that period of non use killed one of the cells in the hybrid battery. I don't have a suggestion, hope you get some(!), just wanted to share my experience in response to your post.
  11. Classic Car Guy
    Classic Car Guy Active Member
    415
    119
    Northwest, USA
    what is the next oil weight up after 5w-30?.
    Maybe I should start using the next heavier oil than what I originally use for mine is going 140,000 miles..
  12. nancytheprius
    365
    156
    iowa
    Well today i surpassed 100k miles on my 06. I bought the car 2 years ago with 63k miles
    in my ~40k miles, the only issue i’ve experienced was an xpress oil change place overfilling the oil. Has never had any issues excluding that. since then i’ve been changing the oil myself every 4500-5000 miles
    I’ve changed all the fluids except the brake fluid. i’ve replaced the pcv valve, spark plugs, filters, and brake pads. The tires were replaced by the original owner, so it’s still on the second set. it has the original hybrid battery. As far as i’m aware everything else is still stock
    jerrymildred and Mendel Leisk like this.
  13. Mendel Leisk
    41,402
    First thought when I saw thread title, can’t be many 2nd gen owners still under 100k miles. Cool to see longevity.
    brake fluid change is a good idea. Dealership shouldn’t charge more than $150 USD I’d think.
    come to think of it, our 2010’s at 95k, kms, so got a ways to go myself. :)
    #933 Mendel Leisk, Oct 17, 2022
    nancytheprius likes this.
  14. Tombukt2
    12,941
    2,322
    Durham NC
    But the fluid still looks as new .like a new Corolla next to you're car etc . You container will be a lil darker than newer car . But on paper towel fluids almost look same.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    LKHF Brake Fluid Tester Detector Brake Fluid Quality Tester https://a.co/eFyCR45
    Phoenix Systems 8006-B Double-Ended Coolant + Brake Fluid Test Strips (15 foil wrapped test strips), 1 Pack https://a.co/ibniOI8
    There are cheap brake fluid tests you can do.
  16. nancytheprius
    365
    156
    iowa
    Thanks for sharing, I just ordered the second option. this will give me peace of mind or urge me to change the brake fluid
  17. Mendel Leisk
    41,402
    FWIW Toyota Canada says 36 months or 48K kms, whichever comes first, for the brake fluid. IIRC they used to say nothing, like Toyota USA. I'm always a little incredulous by these variations, reversals, suspect they have more than the customers' best interest at heart...
    FWIW I've DIY'd this on our 3rd gen a couple of times (info in my signature), but for 3rd gen there is a specific instruction the Repair Manual, including a non-Techstream option.
  18. nancytheprius
    365
    156
    iowa
    it’s definitely overdue! i do have techstream, but currently i have street parking on a hill. If/when my brake fluid tests poorly, I will probably opt to have it done for me. i assume you have to disconnect the brake line at the caliper in the process of swapping fluid?
  19. Mendel Leisk
    41,402
    Just loosen bleed screws. I’ll look again in 2nd gen. Third gen says “change”, while second gen says “bleed” IIRC. But yeah, dealership would know.
  20. Mendel Leisk
    41,402
    2nd gen repair manual only has "bleed" procedure, with Techstream. FWIW, attached:
