100,000 Mile Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EchoToPrius, Jun 14, 2015.
  1. EchoToPrius
    EchoToPrius Junior Member
    Currently have 91,250
    New tires
    Changed out engine air filter
    Changed out cabin air filter
    Oil change every 10,000
    What needs to be done at 100,000?
  2. Mendel Leisk
    42,368
    Are you looking for extra suggestions, beyond what's listed in the Warranty and Maintenance Booklet?
    In that category, I'd suggest a transaxle fluid change, and a brake fluid change, if neither has been done.
    Have you had a decent brake inspection?
    Just for reference, here's what the booklet says:
    The reference "3" postpones the inverter coolant change, to 150,000 miles or 180 months.
    #2 Mendel Leisk, Jun 14, 2015
  3. EchoToPrius
    Brakes are fine
    I was looking at changing the transmission fluid, engine coolant, and spark plugs.
  4. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    WOW, almost 100,000 in 2 years? Congraduation! I would do your top item and these
    1. Transmission flush if you did not do it at 60,000 and 50,000 after
    2. Coolant and inverter flush
    3. Spark Plugs
    4. Timing Belt but Prius are chain so no need
    5. Water pump (if it was me)
  5. frodoz737
    frodoz737 Top Wrench
    4,809
    2,562
    33
    What Mendel said...but disregard Toyota's reference "3". Change both coolants...plugs too.
  6. Mendel Leisk
    42,368
    This is a maintenance summary table from the 2014 Prius Warranty and Maintenance Booklet, the Canadian booklet. If you don't mind doing the aerobics to convert kms to miles, it's an excellent counterpoint to the US event-by-event schedule. This is not the US schedule, but does largely parallel it. Major departures: shorter oil change interval, and inclusion of brake fluid change.
    The Canadian booklet didn't used to have this table; my 2010 booklet is an effing mess, to put it impolitely. :whistle:
    With your spark plugs, it's getting close to time. I tend to pull them out, clean and re-install, at least once, about mid-way through their life. It's not a trivial task though, with the Prius. NutzaboutBolts has an excellent video on this. The only thing: he recommends 20 lb/ft torque, WITH lotsa anti-seize. The Repair Manual says 15 lb/ft, with dry threads. And if you do use any amount of anti-seize, I'd reduce that value, by a pound or two.
    #6 Mendel Leisk, Jun 14, 2015
  7. EchoToPrius
    Is the engine coolant and inverter coolant the same?
    Toyota Genuine Fluid 00272-SLLC2 Long Life Coolant - 1 Gallon
  8. EchoToPrius
  9. Patrick Wong
    18,212
    6,529
  10. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    I'm nearing 100,000 on my 2010 Prius. I bought it used fairly recently. I don't think it had a maintenance schedule in the glove box --- where can I get this?? I'm going to be bringing it to Toyota ... but it would be useful to have. I really want to 'pamper' this car.. I love it! :)
  11. Patrick Wong
    18,212
    6,529
    Rhinoruns likes this.
  12. Mendel Leisk
    42,368
    Google Toyota infotech. Select manual section, then you fill in your make/model/year info and search. Both owners manual and warranty and maintenance guide are in there. They pop up, and you can save as PDF.
  13. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Thank you both! I just joined the Toyota site and was able to bring up all the service records! Of course, I should have thought to go right to the source! Found the maintenance schedule in there too! THANK YOU !!!!!! :ROFLMAO::LOL:
  14. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Yes, I checked on this. The ICE, gas engine and the electric motor (inverter coolant) both use the same coolant. You can use that in both reservoirs. Just bought a gallon of the SLL at my local Toyota dealership.
  15. Mendel Leisk
    42,368
    I did the same thing, both reservoirs were a bit below the low marks. But too bad you can't buy a quart/liter.
  16. frodoz737
    4,809
    2,562
    33
    But it's lifetime fluid :sneaky:. What's left It will keep until needed later.
    Priusguy78213 likes this.
  17. Priusguy78213
    94
    30
    San Antonio, TX
    You're not kidding; checked Amazon, Ebay and others online. Actually the cheapest (at $18.00/gal.) was the Toyota stealership a few miles from my place! lol So I guess on some things they're not a complete ripoff.
  18. Mendel Leisk
    42,368
    Yeah but it's like shopping at Costco, lol. I have to think twice when buying things like the 50 pack of disposable razors, they might outlast me. :ROFLMAO:
  19. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    Similarly, I couldn't find Amazon or anybody else selling Toyota's ATF-WS on-line at a lower price (including shipping) than the local dealer does----although some were very close, and I found several posts in PriusChat by people who'd bought it from dealers at considerably lower prices a couple of years earlier.
    Zerex's Asian Formula antifreeze supposedly meets the specs for SLLC, and sells for a little less.
    #19 CR94, Jun 21, 2015
  20. Mendel Leisk
    42,368
    You know, even if the dealership's a dollar or two more, I'm averse to dispatching FedEx planes willy nilly, just 'cause I need coolant. ;)
