$1000 to make my prius quiet
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Fitpriusdad, Feb 14, 2017.
  1. Fitpriusdad
    Fitpriusdad Junior Member
    Fairfield, California
    I have a 2010 prius IV not Four with 128k miles
    Over the years it's gotten louder and louder. It's especially noisy on the freely. Very difficult to have a conversation. I was wondering what you would do if you had a $1000 budget to make your prius more quiet, what would you do?
    I found that there is a way to dampen the noise by a installing something under the wheels. Also I've heard of dynamat. Also I'm going to pay to do this, I won't be doing it myself.
    Thanks in advance.
  2. JC91006
    16,939
    8,647
    You might have bad tires or bad wheel bearings
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Tires can be a source of noise, so you may want to start there. Are you saying road noise or engine noise? Quite a few Dynamat old posts here I think.
    A while back I had Goodyear ComforTred which was supposed to be quiet, but after some number of years despite OK tread on the rears, they were noisy.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    The Michelin energy saver A/S tires are very quiet ! They made my 2012 liftback very quiet and smooth on the freeway at 75mph. Easy to have a conversation!
    What type of tires are you running right now?
  5. mrbigh
    3,686
    699
    Long Island, NY
    Talking about Dynamat (name brand) and others sound dampening materials alike.
    I does work, very well depending on the thickness of the mats.
    On my 2004, many years ago, I installed 3 layers of similar product on all bottom surfaces, 1 layer inside the doors and 1 layer in between the front door panels. I added and contour a thick cotton mat (carpet padding) over the wheels wells and then the original carpeting above them all. It was like a Rolls Royce, until I turned on the original Bla Bla Bla radio. This is a topic for another thread.
    A good padding job will cost you under 1k, depending where you are located.
  6. bisco
    52,912
    the body doesn't get noisier over time. i dropped 7 bills on michelin e/s, noise was cut in half.
    Mendel Leisk and Aaron Vitolins like this.
  7. Fitpriusdad
    Right now I have the Yokohama yk740 gtx in the rear, just bought last week.
    Front I have sincera sns828 which are about 4 months old.
    However I think my wheel bearings may be the issue. Though I'm not sure because since I got the new tires car is louder. My phone measures at 96 decibels
    Thanks for guiding me in this direction. I didn't even know this. I will take it in to see and report back.
    #7 Fitpriusdad, Feb 14, 2017
  8. bisco
    52,912
    you bought the wrong tyres if you were looking for quiet and/or mpg's.(n) but agreed, wheel bearings can become very noisy. you might be able to replace them, and still have money left over for dynomat.
    Bluegrassman likes this.
  9. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Yes Bisco is right, those are not the right tires for what you are looking for.
    Do you happen to know anyone with a Prius? If so I'd ask them if you could ride in it or drive it. If not maybe the dealership?
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    96 dB seems high. Is there a specific area the sound resonates from? Is it just in the last 4 months with the 2 tires and now with the 2 new tires? What were the dB measurements several months ago? Can you have someone in the car with you and move your phone around to see if they can pinpoint the location? Where do you go for servicing?
    Oh and another Fairfield guy:)!
    Keep us posted(y).
  11. KCobby
    KCobby Member
    229
    74
    NYC area
    Yep, true - just because they're new tires doesn't mean they're automatically quiet.
    That would be good to know. One reading isn't going to tell much.
    I will attest to the energy savers being quiet. LOVED those when I had them on. And they were quiet.
  12. DrTrivia
    DrTrivia Member
    44
    27
    I'll agree with most of the replies above on cabin noise. I had a similar issue with roast nose getting louder and louder. I wound up having a bad passenger side rear wheel bearing. It was impossible for me to tell where the noise was coming from while driving (sounded like driver side front), but after jacking up the car and removing the wheels it was really easy to find the problem. Removal and replacement was fairly easy (you'll need to rent a hub puller). Huge difference once fixed.
    Fitpriusdad likes this.
  13. Fitpriusdad
    I wanted to give everyone an update on the loud noise issue in my 2010 prius. My mechanic said both back wheel bearings were bad. In total , parts and labor cost me $837. Now my car is quiet. He said it was really bad .. super loud at 20 mph.
    kc5dlo, bisco, mmmodem and 1 other person like this.
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Thanks for the update(y).
    What mechanic are you using the the Fairfield area?
    I helped another member a couple of months back with the drivers rear hub assembly and we did that for the cost of a timken assembly (I think it was $150).
    kc5dlo likes this.
  15. Fitpriusdad
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Thanks for the info:).
    Good to know in case I am looking for a good mechanic to do something I would not do myself(y).
  17. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    $1000 to make his car quiet. He got his wish, kind of, bearings at, $800 :)
    Aaron Vitolins and Raytheeagle like this.
  18. bisco
    52,912
    nice call jc.
    m.wynn likes this.
  19. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Haha, I heard the rolling resistance on ComforTred is horrible. Will probably cause a huge drop in MPG. But I bet it's a quiet and soft ride.
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Back in 2008 GY Assurance Comfortred was more common and considered OK LRR but not superior. Also it was a very long life tire (as I can attest) so MPG vs. life trade-off was favorable. But today I don't think we hear as much about them for Prii. In the end as they got old I think they lost traction and got noisy.
