100k miles maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by juul30, Dec 15, 2017.
  1. juul30
    juul30 New Member
    New Albany, Indiana
    So I'm about to hit 100k miles in my 2012 Prius and I was wondering what kind of maintenance I should do on it. I bought the car with 90k miles on it, and the person that owned it before me only did oil changes on it. Right now I have changed the cabin filter, engine filter, and did an oil change myself. Should I do anything else?
    49,505
    yes, there is a maintenance schedule in the owners manual.
    on top of toyota's recommendations, you may want to change the tranny fluid, and clean the egr and intake manifold.
    see nutazboutbolts videos on youtube. all the best!(y)
    Raytheeagle and m3pare like this.
  3. juul30
    juul30 New Member
    New Albany, Indiana
    Ok, there's no exact schedule in my manual more of just all of the things you can do. As for the transmission, I'll go get some transmission fluid later. But the EGR and intake how would I go about cleaning that would something like seafoam work?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Raytheeagle and bisco like this.
  5. bisco
    49,505
    idk, i'm only at 55,000. there are some seafoam threads here, and did you look at youtube?
    #5 bisco, Dec 15, 2017
  6. juul30
    juul30 New Member
    New Albany, Indiana
    Thanks for the link! I figured I had to do those things but do things like the brake fluid need to be changed out as well? I just want to be thorough
    Yes, I did it seems to be the only thing that actually cleans debris effectively. I don't have the knowledge to clean those parts by hand.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I believe @Mendel Leisk used Oxyclean to clean some parts.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Brake fluid builds up moisture over time. Obviously Miami will have more moisture in the air than Phoenix, so it is not usually a 'miles or months' kind of maintenance item. You can use testers to determine moisture.
    amazon.com/Automotive-Diagnostic-Testing-Calibrated-Indicator/dp/B01EOD7INK
    there are also test strips
    amazon.com/Phoenix-Systems-3003-B-Package-Condition/dp/B00E6TXWA6
    Prodigyplace likes this.
  9. juul30
    juul30 New Member
    New Albany, Indiana
    Ok, everything seems easy enough to do I'll go to the store later and buy the stuff. Thanks for all the help guys!
    bisco and Raytheeagle like this.
