100k miles service--just checking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Dec 10, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Lovely indeed
  2. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Don't forget to keep us updated! I'm anxious to hear the final result.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    You Got To Be shi**ing ME.
  4. Bob64
    1,540
    93
    Virginia
    looks like their twist ties weren't long enough to reach the holes.
  5. boppo
    boppo Active Member
    799
    139
    Owego, NY
    the plastic retainers work as designed. don't understand that pic.
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    What is wrong with using the plastic clips? They work FINE. My sister pulled the mat in her 2005 wen she got her recall letter. The OEM mats in our '04 and '06 are still in and NO problems. The whole floor mat recall thing is a farce.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
  8. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Maybe a GM new hire came up with that idea.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hey Doc, did you get your car back yet?
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just got home with it less than an hour ago!
    Final total came to $878. I did get the alignment included in the tie-rod Extended Warranty repair costs.
    Brakes were in fantastic shape, no need to worry about those for another 50k miles or so. They did replace my belt...I'll have to take their word that it was needed.
    It was interesting to hear the whine of the heat recovery pump again, it must've died this summer sometime b/c I remember hearing it squeaking last winter and thinking it wasn't squeaking in the summer b/c it was warmer...but now I know it was simply dead.
    I'm not sure if they did something, but the steering feels a bit more sure, less play in the steering wheel...maybe my imagination after almost 2 weeks away.
    It may also just be that the battery and inverter was really cold, but I had a stop after the ICE had well passed 168F shortly after picking up the car and the ICE would not shut off and do the usual idle check to enter S4!? The climate control was off, there were no other unusual power drags that would force it to stay on. Battery was right at 51F, Inverter was 68F. Once it did get into S4 it seemed to work fine.
    It may be my imagination, but the car sounds a bit more "throaty" too. Now, there's also a slight rattle on bumps and I suspect they did not attach my BT Skid Plate properly. When I'd first put it on there was some contact b/w the plate and the engine block and it created a similar 'rumble'. I'm going to have to crawl under there and see if they put my spacers back in so that there's no contact.
    Since the car was outside on their lot for 10-11 days it was filthy...I sure wish they'd have thrown in a free car-wash/detail for the delay... oh well.
    All requested services were documented and completed.
  11. paprius4030
    2,077
    296
    York,Pa.
    Glad you got your car back Doc. A question though... How do you measure the temp of the battery and more impotantly the inverter? I thought it was impossible to get the inverter temp. that's why people are so nervous about the inverter pump failing?
  12. zmre2b
    zmre2b Junior Member
    70
    US
    could you itemize that?
  13. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    the tech was sure happy to have that warranty alignment- pretty much the only instance where warranty pays better ;) the alignment could have improved your handling a bit.
    you sure the pump failed? it should have triggered a code.
  14. efusco
    19,891
    1,196
    Nixa, MO
    I can do that tomorrow...or I'll scan the paperwork and post it..though it'll probably be easier to read if I just copy the important stuff, it's a PITA to interpret.
    In the mean time, you can look at the original list of items in the OP. All that was done for me, the coolant pump and alignment were covered under warranty, I had to pay for a new belt.
  15. efusco
    19,891
    1,196
    Nixa, MO
    Cool, hope he made a bit as clearly my car was a little bit of a pain and I was pretty specific in my list of items to do. He had to deal with the skid plate and apparently my pipe insulation grill block threw everyone for a loop!
    I thought so too, but I never had a code. But I am certain that the pump never ran for the past 6+ months. In cold weather it was hideously loud previously...you couldn't miss it.
  16. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    He has CAN-View, which shows inverter temps.
  17. paprius4030
    2,077
    296
    York,Pa.
    Can you tell me more about Can-View? I just have a scanguage 2.
  18. efusco
    19,891
    1,196
    Nixa, MO
    CAN-view index
  19. efusco
    19,891
    1,196
    Nixa, MO
    Itemized List: (costs rounded to the nearest dollar by me)
    Hourly Rate-$85.00
    Brake Flush-$75
    Brake Fluid-$7
    Total- $82
    Clean & Adjust Brakes -$37
    4-wheel Alignment- $0 (covered under Extended Warranty)
    PCV Valve
    Labor-$15
    Part-$11
    Total - $26
    Throttle Body Clean
    Labor-$37
    Fuel Induction Kit/parts-$41
    Total-$78
    Spark Plug Replacement
    Labor-$85
    Parts-$66
    Total-$151 (this seems a bit ridiculous...should have done it myself)
    *Comment that "incorrect plugs previously in vehicle"--curious since they're the original plugs!
    Fuel Injector Clean -$60
    Mass Air Flow Sensor Clean -$43
    Inverter Fluid Change
    Labor -$43
    Fluid -$22
    Total -$64
    Serpentine Belt Replacement
    Labor -$85
    Part -$22
    Total -$107
    Inspection of Suspension/Exhaust/CV Joints-- led to discovery of frozen tie rods, one Tie Rod end-assembly replaced under warranty--Apparently they also replaced a license plate bulb and my cabin air filter under warranty!? That's particularly curious since I specified no oil or filter change up front. But no charge...:cheer2: -$0
    Replace Engine Coolant
    Labor-$85
    SLL Coolant-$22
    Radiator Conditioner -$10 (I didn't ask for that)
    Total -$117
    Heat Recovery Pump- $0 (under Extended Warranty)
    Transaxle Fluid Replacement
    Labor -$43
    ATFWS (4 quarts?) -$40
    Conditioner -$15
    Total -$97
    Tax-$17
    Grand Total - $879
    2 people like this.
  20. Patrick Wong
    18,210
    6,513
    Very fair prices. Glad your car is back in service now & that you didn't have to pay for the alignment.
