10k BlackStone Lap Oil Report
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by priusCpilot, May 4, 2013.
  1. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    Still had 1500 more miles left on the 0-20w Toyota Synthetic Oil and K&N/M1/Champion Laps Oil Filter.
  2. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Report says 5w-20?
    X
  3. priusCpilot
    631
    209
    LA
    Are you sure? Please check again. Lol
  4. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Quote:
    GEORGE: Our overall finding in this report is that your Prius' engine is still maturing very nicely. Most
    metals (including iron, copper and lead) and silicon have all dropped pretty significantly since last time. The
    one exception is aluminum, which increased by a mere 2 ppm over this oil run. That may show a little extra
    piston wear, but at this point it's really nothing to get excited about. It should taper off in your next reports,
    and other metals should continue to improve as well. The TBN still was good at 2.3, so go up to 11,500
    miles on your next report. Check back to monitor.
    04/01/13
    12 PRIUS
    Gasoline (Unleaded)
    Toyota 5W/20 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    0 qts
    06/22/12 03/23/12
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The aluminum generation is actually reducing, not increasing. The previous run was ~5k miles, this one was ~10k miles so there is less aluminum per mile in the latest batch. It is showing less piston wear, not more.
  6. priusCpilot
    631
    209
    LA
    Click on the report again hehe
  7. priusCpilot
    631
    209
    LA
    Good point!
    Many on BITOG have reported outstanding results with this oil. Much better then the M1 0w-20. Even though Exxon makes this proprietary blend to Toyota specs. Some have reported that this may even be a better base stock then what is in M1? Im also certain that the filter used played a roll in this report.
